Old 07-16-2016, 03:59 PM   #1
chideock's Avatar
12 V Battery Connection
I am asking which of the diagrams below is the correct way to connect two 12volt batteries in my motorhome? Or does it matter?
First diagram shows how the batteries in the old motorhome were connected.
Second shows how my new motorhome batteries are connected.
2016 Sunseeker 3010ds towing a 2013 Ford Explorer 3.5L AWD.
chideock is offline   Reply With Quote
Old 07-16-2016, 04:18 PM   #2
fonzie's Avatar
#2 is best
Fonzie
Nights Camped: 2011(21) 2012(36) 2013 (17) 2014 (18) 2015 (18) 2016 (36) 2017 (4)
Old 07-16-2016, 04:23 PM   #3
SeaDog's Avatar
X2 with #2
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
AF&AM of Idaho
Old 07-16-2016, 04:29 PM   #4
x3 for second connection.
2007 Surveyor SV230
- 200 Watts Solar/MPPT Controller - 230 AH Battery Bank - 600 watt PSW Inverter - (2) 2000 watt Inverter Generators - LED Lighting - Boon Docking 99% of the time.
2009 F150 - 5.4 Litre - 6 speed - Tow Package
boondocking is offline   Reply With Quote
Old 07-16-2016, 04:34 PM   #5
Kenny kustom's Avatar
First connection will draw equally though both batteries.
Both will work. First one works better.
2016 Sabre 36QBOK
2015 Ram 3500 CUMMINS
2017 Dynamax Isata 4
Old 07-16-2016, 04:44 PM   #6
BandJCarm's Avatar
Well, I flunked the Smarty Pants thread...........so I probably will expose more ignorance here.......
But, other than the pictures and the batteries are turned 90 degrees from each other, what is the difference? Both are wired in parallel. The only true difference I see is that in #1 the neg goes to neg on the source, and in #2, the neg goes to a ground.
FROG AR-0019-242
BandJCarm is offline   Reply With Quote
Old 07-16-2016, 04:46 PM   #7
raspivey's Avatar
Honestly, you shouldn't see any difference at all. You're not really "pulling" through one battery into another as you would with a series connection. You're just tying posts together and drawing from both at the same time. One battery may be slightly less efficient, but that will be due to the resistance in the wire between the two, which will be negligible.
Old 07-16-2016, 04:48 PM   #8
Basically the batteries are joined.
Pos is hooked to one battery, neg to the other. That way current is drawn through both.
It matters more during high current/load situations, but if you can do it correctly, why not?
2016 Sabre 36QBOK
Old 07-16-2016, 04:51 PM   #9
If you want to get really fancy.
This one goes as far as equal length cables.
Even on my two battery setup, I tried to be as equal length as possible. Click image for larger version
Name:	ImageUploadedByForest River Forums1468705883.290728.jpg
2016 Sabre 36QBOK
Old 07-16-2016, 04:51 PM   #10
Flybob's Avatar
Slightly OT, but more important than which method you choose is that the batteries be of same type, equal capacity and very close in age.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 65W solar panels
battery
