Old 07-24-2012, 04:05 PM   #1
Hitch Pin's Avatar
12 VDC TV Receptacle for cpap?
Hi All
I sleep with a cpap that will run on 12VDC, I have a adapter cord that will plug into a 12VDC lighter receptacle. Does anyone know if you can use the 12VDC receptacle that is for the TV to run other stuff? The cpap only needs 5amp and the TV receptacle is good for 8amp.
Hitch Pin is offline   Reply With Quote
Old 07-24-2012, 04:29 PM   #2
Dave_Monica's Avatar
So it sounds like the receptacle max rating is 8 amps, the cpap draws 5 amps, you're good to go!
Dave
Old 07-24-2012, 04:56 PM   #3
I assume that 5 amps is running a heated humidifier. If you cut that off, or at least down, the cpap machile itself won't draw nearly 5 amps.
Pinesman is offline   Reply With Quote
Old 07-24-2012, 06:07 PM   #4
n1joh's Avatar
plug for cpap
i am also on a cpap machine. when i had my other motor home i put a dedicated plug next to the bed for my machine. i ran a wire stright to the panel so i did not have any problem when i ran it.
n1joh is offline   Reply With Quote
Old 07-24-2012, 06:39 PM   #5
Post RESMED Mirage S8 CAUTION
If you have a ResMed Mirage S8, it won't work, it will blow a fuse in the S8. The center of the 12v cord that fits in the S8 is NEGATIVE and cigarette lighters are wired for the center to be POSITIVE. Tried it twice and had to send the S8 back to the factory both times to be repaired before I found out what was causing the failures. 1st time was $150, 2nd time was free because it was within 30 days. Big problem is the 4-5 week wait for repairs.
Old 07-25-2012, 08:46 AM   #6
Hitch Pin's Avatar
I have a Respironics PR System One
Old 07-25-2012, 10:42 AM   #7
Some way, you need to see if it is wired the same as the S8, and if it is, reverse the way the 12v socket is wired. I would also mark the 12v outlet as being wired different. This is just a sneaky way for Respironics to force you to buy their power source.
Old 07-25-2012, 11:11 AM   #8
Hitch Pin's Avatar
My Respironics is 12v + in the center.
Old 07-25-2012, 04:58 PM   #9
Hitch Pin's Avatar
ON the main page it says this thread was moved, where was it moved to?
Old 07-25-2012, 06:24 PM   #10
n1joh's Avatar
cpap users
sorry i did not finish before i sent. i install a 12 plug so i could use my inverter 12 volt to 110. then plug in the cpap unit i know from looking at my unit that the 12 volt plug was reversed.
