Old 07-14-2014, 05:56 PM   #11
KMP44
I do have a 40amp fuse. Should it 30amp?
Ok, I put a 20amp fuse in and it work.
Just need to know if i need a 30amp fuse.
Thank you all for helping solve this problem.
jimvincent is offline   Reply With Quote
Old 07-14-2014, 08:44 PM   #12
Triguy's Avatar
Originally Posted by Offagain View Post
I know that I have one about 2 feet or so from the battery. How do you reset one of those?
See that little button on the side of the gray breaker in the picture above? Press that to reset if needed.
Originally Posted by jimvincent View Post
KMP44
Glad you solved the mystery. But, you should use the correct size fuse for your camper. I said 30amp previously but that was presumptuous as I don't know what the correct one is for your trailer.
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 07-14-2014, 11:02 PM   #13
Where should we go next!
Offagain's Avatar
[QUOTE=Triguy;658459]See that little button on the side of the gray breaker in the picture above? Press that to reset if needed.
Thanks Triguy.
I've read it mentioned many times that they are resettable, I just couldn't figure out how.
Ford F-150 4X4 Supercrew Ecoboost
Surveyor SV291
Equalizer 4-point 10K lbs.
Offagain is offline   Reply With Quote
Old 07-14-2014, 11:12 PM   #14
Batts-toy's Avatar
Check for a reset button (usually black or red on the side or end of the breaker (you can see it in Tri-guy's post above). push and release if this don't work use a test meter and check before and after the breaker, you may need to replace the breaker or test further. EDIT: I see you got it solved, congrats.
Dale & Terri, Lulu & Tiki (our Chihuahua's), New rescue puppy Prince - Pom/Pug mix.
2013 Tundra, Double Cab, 5.7, TRD Off-Road, 4X4, Full Tow Package
2013 Wildwood T26TBSS - Sold
2000 Gulf Stream Sun Voyager M-8357 MH, Ford Trident V10 Gasser, 35 foot.
Batts-toy is offline   Reply With Quote
Old 07-15-2014, 08:57 AM   #15
KMP44's Avatar
KMP44
Generally, you won't hurt anything if you go with a smaller fuse - it just might be more prone to blow. Probably your best bet is to check with your dealer or find a member with the same trailer to verify what the right size fuse is. Glad to hear you got it working.
2017 F-250
2013 Rockwood Roo 23 IKSS
KMP44 is offline   Reply With Quote
Old 07-15-2014, 10:10 AM   #16
Offagain's Avatar
If this is a resettable fuse, do they go bad and does anyone carry a spare?
Never had a problem, but thinking of buying a couple and storing in the rig.
Surveyor SV291
Old 07-15-2014, 10:25 AM   #17
TURBS's Avatar
If it is resetable id replace it with a auto resetting circuit breaker.
Yes they do go bad.
And they just wont reset anymore.
Old 07-15-2014, 12:27 PM   #18
Offagain's Avatar
Yes they do go bad.
Ok, thanks.
Surveyor SV291
12 volt, battery
