Old 07-14-2014, 09:16 AM   #1
12 Volt Battery problem
My Battery is reading 12.44 volts.
Lights inside my camper not working.
Any suggestions?
2007 Forest River, Flagstaff, 625D Model
jimvincent is offline   Reply With Quote
Old 07-14-2014, 10:22 AM   #2
Where should we go next!
Offagain's Avatar
Are you plugged into shore power? If not, plug in and let your converter top off your battery. If that doesn't do it, it may be a bad battery or converter. I just replaced both on mine. New group 24 battery from Costco=$90. New PowerMax MainBoardAssembly(Didn't need to replace the whole converter, just the board) =$125.
You can see a video of a MBA swap out here.
Hope this helps and good luck.
Ford F-150 4X4 Supercrew Ecoboost
Surveyor SV291
Equalizer 4-point 10K lbs.
Offagain is offline   Reply With Quote
Old 07-14-2014, 10:34 AM   #3
Offagain's Avatar
There's a way to test your converter at the battery with a volt meter. Someone here will chime in with that.
On mine, I wasn't getting any DC power with the camper plugged in and the battery disconnected. It always used to. Called WFCO and explained it to them and they said"That's a tell tale sign your converter died".
Battery was old so I just went ahead and replaced it. It hadn't been holding a charge for very long for quite some time. I never boon dock so I didn't bother getting a new one. However you do need a good battery hooked to rig while plugged in because the battery acts as a buffer for the converter. If no battery while plugged in, the converter will put out full power,shortening the life of the converter.
Surveyor SV291
Old 07-14-2014, 10:36 AM   #4
Triguy's Avatar
Have you checked all of the breakers and fuses at the converter and within and outside the camper?
You should have a resettable breaker between the battery and your camper's converter (located on positive wire usually a few feet behind the battery). I'm not familiar with your model, but that's one of the first thing I would check. Here are two pics of common types. It might have a plastic cover (green and red are common).
You might also have a separate 30amp fuse. If so, check if its good.
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 07-14-2014, 11:04 AM   #5
Offagain.
I do have lights working when plugged in to shore power.
Brand new battery. Also lights work when plugged into my vehicle.
Old 07-14-2014, 12:14 PM   #6
Offagain's Avatar
How long has the battery been connected to the camper without being plugged into shore power? I know on mine, the battery will go dead if I leave it connected for a week or so without having it plugged into shore power.
Something in my camper draws power from the battery when it's connected and everything is shut off. Don't know what it is, but it kills my battery.
I remove my battery when I get home and leave it connected to a battery tender.
A lot of forum users have battery kill switches on their campers to prevent killing the battery when camper isn't being used.
Try plugging into shore power and see if it charges back up.
Surveyor SV291
Old 07-14-2014, 12:18 PM   #7
Offagain,
My battery is reading 12.4 volts... So it's fully charged...Just no 12 volt power to any of my lights inside the camper? I will check all the fuses tonight when i get home.
Old 07-14-2014, 01:49 PM   #8
Offagain's Avatar
Odd that you're getting lights while connected to tow vehicle, but no lights without.
Give it a little time. There's a lot of pretty sharp folks on here. In sure someone will be on here later on after work.
Surveyor SV291
Old 07-14-2014, 02:04 PM   #9
KMP44's Avatar
Follow the advice Triguy listed. 12.4 volts is plenty to run your lights. They are working on shore power, which means they are being fed from your converter. There is a disconnect between the battery and the panel. Most likely its that resettable breaker under the frame or possibly an in-line fuse.
2017 F-250
2013 Rockwood Roo 23 IKSS
KMP44 is offline   Reply With Quote
Old 07-14-2014, 02:16 PM   #10
Offagain's Avatar
I know that I have one about 2 feet or so from the battery. How do you reset one of those?
Surveyor SV291
12 volt, battery
