Originally Posted by Sewtek
Installed new battery in April. It went bad on me. Got a new one but still have issue when not hooked up to 110v power, I have no interior lights. Checked ALL fuses and they are good. Concerned it may be converter. Any ideas??
The converter is what powers the lights WHEN connected to 120 volt AC (shore power).
The battery is what powers the lights when NOT connected to 120 volt AC.
If you don't have lights when not connected to shore power, but do when you are connected........... then you are not getting power to/from the battery.
Suggestions to check: a battery disconnect switch, a fuse inline near the battery. and the 12 volt dc (aka resettable fuse) if equipped.
Also something else to note, your converter recharges your battery. If it cannot get power to the battery, your battery will not be recharged unless you connect it to a battery charger.
