don't know how yours in cabled. on ours the converter is midway between the 12 volt fuse box and the batteries. also I believe the slide outs and levelers have in line fuses that are near the batteries and are not in the fuse box. could it be that you have a loose connection going from the converter to the battery? there could be 12 volts from the converter to the fuse box to run the lights but the loose connection is keeping it from going to the batteries. or could the battery disconnect switch have the batteries disconnected? even if this is so, if plugged into shore power the converter could be supplying 12 volts to the fuse box. also, the 12 volt lead on the 7 pin connector is often wired directly to the batteries. one test would be disconnect from shore power and see if the lights will come on. if not you know they are being powered by the converter when connected to shore power. if so there is some form a loose or broken connection between converter and batteries. double check battery disconnect switch
2015 cardinal model 3825fl
2015 dodge ram 3500 dually
