Old 06-01-2015, 10:56 AM   #1
12 Volt Power Issue Windjammer 3008W
While I was pulling the slide in my husband disconnected the 110 power cord. I then lost all power to the trailer. Plugged it back in to shore power there was a lag time before it came back on again but now when disconnected from shore power we have no power at all in the trailer. The battery is charged and when connected to the tow vehicle we only have power if the truck is running which is weird. Where is the power converter on a 2015 Windjammer 3008W or is there a main fuse for 12 volt operation?? We also had the surge protector on. Any ideas would be greatly appreciated. Thanks
CLewis is offline   Reply With Quote
Old 06-01-2015, 11:05 AM   #2
12 volt
check your disconnect switch. up front by the propane bottles.
2OLDDIGGERS is offline   Reply With Quote
Old 06-01-2015, 11:12 AM   #3
Already did that - I wish that was the problem. Thanks
Old 06-01-2015, 11:18 AM   #4
D_B Travelers's Avatar
Also, remember the surge protector has a built-in delay of about 2-1/2 minutes. Or my Progressive does anyway. The battery may be charged and show 12+ volts, but you may want to take it and have it checked under load at a shop. I have had a battery that checked good on volts but didn't have enough amps when a load was applied. You said everything was dead. Interior lights also?
D_B Travelers - 8 nights in 2018, 58 nights in 2017. [U]1st love: 2014 TT WJ3001w, now 2016 40' FW SOB, 2015 GMC 3500HD CC DRW Duramax, TST 507rv TPMS.
"Happiness? A good meal, a good cigar and a good woman - or a bad woman; it depends on how much happiness you can handle."
George Burns (1896 1996)
D_B Travelers is offline   Reply With Quote
Old 06-01-2015, 11:34 AM   #5
fonzie's Avatar
Check underneath trailer near tongue for a mini-breaker and press black button to reset. Hope that will do it.
Fonzie
Old 06-01-2015, 11:56 AM   #6
All lights are off and looked we don't have the black button under the a frame. Thanks
Old 06-01-2015, 12:30 PM   #7
Oh boy, then I am thinking that the converter has died perhaps. I hope you have some other responses on this, but I have no experience troubleshooting the converter...yet. I will keep an eye on the thread so I can learn also.
Old 06-01-2015, 12:31 PM   #8
Battery
Battery dead or not connected. Have it tested.
Harkerr is offline   Reply With Quote
Old 06-01-2015, 12:39 PM   #9
That was my husbands next thing to do. The battery shows fully charged by he's thinking he should have it tested with a load on it. Hopefully it is just the battery.
Old 06-01-2015, 12:47 PM   #10
Eaglelover's Avatar
Send a message via Skype™ to Eaglelover
If when you plug back in and have 12v power then the converter should not be the problem. I would connect a set of jumper cables to the TT battery and see if you get power. Frank
Eaglelover is offline   Reply With Quote
12 volt, 3008w, power, windjammer
