Old 10-31-2013, 04:04 PM   #11
Witch Doctor's Avatar
Originally Posted by BarryD0706 View Post
I'm saying that if he puts a battery disconnect in that wire there will not be (when it's disconnected by the switch).
Tim966, may I suggest that, whether you put the disconnect switch on the positive or negative side, that you leave a path for the circuit that powers your emergency breakaway brakes so they are not affected by your new switch.
Well that part is correct, so you need to see and tell how your breakaway is wired that's all I'm saying. Some are wired thru the disconnect and some are not. That is important to know, nothing else. If you pull the plug and your breaks do not lock up after you disconnect the main pos. it is connected thru the disconnect if if still locks up then it is wired directly to your battery. What is hard to understand in that statement?
Coachmen M/H
Concord
2018 / 300 DSC
Old 10-31-2013, 04:11 PM   #12
X2
Old 10-31-2013, 04:23 PM   #13
dannyabear's Avatar
WHY would you need brakes when stored? It's not like they work anyway when not moving.
Danny & Darlene
2002 Silverado 1500HD
2014 Rockwood 2703WS 'Emerald Pkg'
Days camped 2015=42 2014=48 2013=41 2012=47 2011=18
dannyabear is offline   Reply With Quote
Old 10-31-2013, 04:30 PM   #14
Fulltime family RVer
It's the emergency breakaway brakes. The fear is that with a disconnect that disconnects them may be forgotten to be re-enabled when you go to get the camper out of storage. If forgotten and the worst happens and the campers separates from the tow vehicle, the brakes wouldn't be applied.
This reminds me that I really need to test this... on my own disconnect switch installation.
Old 10-31-2013, 04:36 PM   #15
He does not have a disconnect switch to "see and tell" about. This thread is about adding one.
Old 10-31-2013, 04:37 PM   #16
dannyabear's Avatar
Whenever I disconnect anything important, I put a yellow tag on the coupler or wiring plug to remind me the next time.
Danny & Darlene
Old 10-31-2013, 05:39 PM   #17
Barry I understand that, but he needs to find out how it is wire now before he adds the disconnect. He has to know were his wires go's that all I'm saying again.
Coachmen M/H
Concord
2018 / 300 DSC
Old 10-31-2013, 05:56 PM   #18
X2!
Old 11-02-2013, 08:41 AM   #19
Cheaper, but more of a pain. I pull my battery and place it on a battery minder in my garage. I only do it if I'm not going to be moving for more than two weeks or so. Just throwing an option out there.
meck51 is offline   Reply With Quote
12 volt, battery, power
