Old 03-07-2016, 09:56 AM   #1
12 Volt Problem
Last weekend I went to my Roo 23IKSS in storage to take care a few thing. The battery has been in my basement on a trickle charger all winter and I brought it with me to extend the slides. I hooked up the battery and nothing happened when I tried the slides or the power jack. The first thought that the battery was dead.
I was in a bit of a hurry so I tried hooking the umbilical cord from the TV to the trailer and both slides, lights and power jack worked. I did what I needed to do in the trailer and went home and tested the battery which tested fine.
So now I am wondering, did I have the battery kill switch engaged and would the power still get to the trailer from the TV if this was the case or do I have another problem that is preventing power from getting to the camper from the battery. The battery was connected correctly. I will need to get back out there time permitting to do more forensics. I have a trip April first that I need to get ready for.
2015 Rockwood Roo 23IKSS
2015 GMC Sierra 1500
Archicamper is online now   Reply With Quote
Old 03-07-2016, 10:08 AM   #2
Flybob's Avatar
If you have a battery shut off, That would be the first place I would check. That switch is normally directly between the battery any other wiring on the trailer. Even with shut off in off position, the 12V aux from the TV would power the jack and slide. If the switch is on and you still have the problem, it could be a bad battery. Batteries can test good ( vai voltage check) but have the voltage drop substantially as soon as they are under load and fail to operate the slide etc. You can have this checked at most auto parts store.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 03-07-2016, 10:09 AM   #3
AquaMan's Avatar
I think you figured it out. Had the battery disengaged.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 7
Old 03-07-2016, 10:55 AM   #4
I think so, I wasn't sure if the power from the TV bypassed the switch or not. Apparently it does!
Old 03-07-2016, 11:00 AM   #5
Fulltime family RVer
Mine does.
Old 03-07-2016, 11:01 AM   #6
AquaMan's Avatar
I've seen that happen a lot here recently. Folks get to new camper and/or one that has been in storage for a while, and they forget about the little things.
Old 03-07-2016, 11:41 AM   #7
TURBS's Avatar
12 Volt Problem
" normally" the landing gear and slide power is direct to battery.
Battery cut off wouldn't matter.
Normally the battery gets hooked backwards!
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
Old 03-07-2016, 12:53 PM   #8
2015 Columbus 320RS
2008 2500HD Duramax
I thought the power jack bypassed by the cut off switch as well but apparently that is not the case.
Old 03-07-2016, 12:58 PM   #9
Recently new!
Paulie1138's Avatar
Send a message via AIM to Paulie1138
Test Battery
Harbor frt has an inexpensive ($14 with a coupon?) battery load tester that is good enough to test fry your battery sets. Loads them down to 100 amps with an ammeter, and volts. Helps weed out batteries that seem to test OK until you load them down.
1987 Starcraft Nova tent trailer, purch. '87, sold 8.14
2013 Crusader 290RLT bought new, 8.14
2001 Ford F-250 7.3
A Loving wife and Mason the always dirty dog!
Paulie1138 is offline   Reply With Quote
Old 03-09-2016, 10:19 PM   #10
Too Tall's Avatar
My power jack works regardless of position of shut off switch but my slide needs the shut off switch on to work. There is about 40 ma drain on my battery even when the switch is off and everything in the trailer is off.
Rockwood 2104S, 2014 Ram 2500 Diesel.
USMC 68 -70
Too Tall is offline   Reply With Quote
12 volt
