Old 12-26-2015, 04:05 PM   #11
im not sure were my GFI reset button is located but will look for it when i get there tonight...
llawson2 is offline   Reply With Quote
Old 12-26-2015, 07:22 PM   #12
Scubanut's Avatar
Never wire a neutral(white wire) to a ground wire. Very dangerous. Wire the ground wire to the electrical box.
2012 F150 FX4 Crew 5.0 3.73
2012Coachman Freedom Express 292BHDS (outdoor Kitchen)
Scubanut is offline   Reply With Quote
Old 12-26-2015, 07:31 PM   #13
Todouble's Avatar
What's the difference when they both land on the same neutral/ground bar in the breaker panel? Just asking?
Todouble is offline   Reply With Quote
Old 12-26-2015, 07:51 PM   #14
Scubanut's Avatar
Maybe I'm not understanding what you did! I just know that the white wire goes on the neutral bus bar in the circuit breaker panel. And at the other end on your outlet box the white wire will go onto the silver screw in the receptacle. The black wire goes onto the circuit breaker in the main panel and on the gold colored screw on the outlet box. The ground wire which is normally copper with no plastic covering is put onto the grounding bus bar in the circuit breaker panel and on the outlet side it would attach to the box and a short wire from the outlet to the ground point on the box using a pigtail connection. If you attach that copper wire to the neutral bus bar it defeats the grounding safety and it may cause your trailer to be live and could be fatal if the right conditions occur.
I'm not an electrician but have wired up many things.
Old 12-26-2015, 08:40 PM   #15
My main box at the pole does not have a neutral line that comes from the meter. I only have two main lines from the meter that goes to the main breaker. I can hook the ground to the box which is connect to ground down the pole in the ground and connect the white to the ground bus bar but they will still be connect in a way. White will not go back to the transformer...
Old 12-26-2015, 08:44 PM   #16
The neutral and ground should only be bonded in the main panel or sub-panel. This is done to ensure the correct operation of any breakers should there be a short between the hot and ground on the circuits they protect. Without the bond the breakers would only protect for a short between the hot and neutral. You should never bond the neutral at the outlet or an auxiliary panel (which is what this sounds like to me without more detail).
You said you can get voltage at the inlet to the trailer but no voltage at the converter?
Do you have any type of power protection between the inlet and converter? It might be detecting a power fault and not allowing the trailer to power up.
Have you verified that the outlet is wired correctly such that the hot is going all of the way through to the correct lug on the converter? This could result in a reading of zero volts although the inlet shows voltage if you are reading the neutral and ground instead of hot and neutral on the converter.
keith_h is offline   Reply With Quote
Old 12-26-2015, 08:53 PM   #17
Bluepill's Avatar
If you have a transfer switch for a generator or inside of a built-in inverter you could be loosing the circuit there. An input/output test will tell you.
2008 Itasca Meridian 37H
Old 12-26-2015, 08:56 PM   #18
Scubanut's Avatar
Name:	ImageUploadedByForest River Forums1451185029.252410.jpg
Old 12-26-2015, 09:02 PM   #19
no generator and no switches... this all worked monday when I first hooked everything up and now nothing... im going to look for a GF protection when I get back to camp later tonight. I had seen the picture before but like i said I do not have a neutral wire coming from the meter.. only two power wires.
Old 12-26-2015, 09:09 PM   #20
Flybob's Avatar
Do you have a surge guard. Some of them have protection in them that shut the power down if there are issues and depending on what the issue is may have to be manually reset.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
