Old 12-27-2015, 08:10 PM   #31
UPDATE!!! Found a burnt wire where my power cable connects inside the camper. I cut the burnt wires and reattached and now everything works. Thanks for everybody's help...
llawson2 is offline   Reply With Quote
Old 12-27-2015, 08:27 PM   #32
Mr. Dan's Avatar
Great news!
Thanks for reporting back.
SEARCH is your friend!
Nights Camped: '13 = 49 / '14 = 74 / '15 = 74 / '16 = 85 / '17 = 110 / '18 = 28; booked = 34
Old 12-27-2015, 08:31 PM   #33
Wobbles's Avatar
Glad you are back online. Now find why it burnt.
Keep the faith and keep sharing. We all learn from these conversations. Oh yah, post pictures for people like me that have not seen the components and condition.
If you want, add your rig age and model to your signature. Might help folks with ideas as to a resolution or place to start.
Bob & Michelle
2016 Ford F-250 Lariat 4x4
2017 Flagstaff Super Lite 526RLWS
Wobbles is online now   Reply With Quote
Old 12-27-2015, 08:39 PM   #34
Flybob's Avatar
A burnt wire at a connection usually means that the connection was loose which results in a high resistance connection ( generates heat). I would check the remaining connections in the area to insure they were secure as well. Poor connections usually reveal themselves when the current draw is high. Glad you found it and shared your resolution.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 12-27-2015, 09:32 PM   #35
You're lucky it didn't burn the camper, too! Maybe you should buy a lottery ticket!
2011 Traverse LT, 3.6L, FWD
Old 12-28-2015, 07:05 AM   #36
derek6669's Avatar
llawson2, Bravo Zulu
derek6669 is offline   Reply With Quote
Old 12-28-2015, 07:26 AM   #37
I agree with D.J. Schuler about getting a Progressive EMS Box. It saved my electronics as well!
hardoiler is offline   Reply With Quote
Old 12-28-2015, 10:53 AM   #38
FWIW The ground and neutral went to the same buss for years. When GFI's became common the code was changed to split ground from neutral.
FWIW 2 if you look at the spec for a camper outlet it specifies bonding ground and neutral at the box on the pole/wall/whatever. It is not a shock hazard.
nothermark is offline   Reply With Quote
Old 12-28-2015, 10:56 AM   #39
TGR
TGR's Avatar
Iím glad to see your loss of power was discovered and fixed. However, I am concerned that you still havenít added a proper ground circuit to your wiring.
An electrician can quickly add a ground circuit to your setup and make sure your wiring is safe. There are too many possible variables in your setup to give a specific solution; therefore, an electrician is the best way to get it done properly.
2015 Wildcat 282 RKX
2011 F350 Lariat, 6.7 L. Diesel, 8 ft., SRW, Reese R20
TGR is online now   Reply With Quote
Old 12-28-2015, 08:02 PM   #40
What is wrong with his system and why?
