Hi all,
A weeks ago I replaced a couple of LED lights in the kitchen area. Very bright white lights, a good change from the other LED yellowish lights that were there. Lo and behold, three days later, one of them went out. I opened up the reflector and surprise: it was blown to smithereens. Like 100 pieces of electronics. I took it back to the store (Camping World) and they refunded both LEDs, I figured it was a bad batch.
This weekend, I purchased some more and replaced 6 of them. Well, three of them blew this morning in the span of 5 minutes. Again broken into 100's of pieces.
For a little while I have suspected something is wrong with the 12V system: fans (kitchen, furnace, etc) along with the incendescent lights in the bath room fluctuate periodically, but not on a regular cycle. Today, after the LED incident, I took measurements on the DC supply. When the fans run faster, voltage reaches up to 17V, and "normal" speed shows voltage of 13.5V. The converter is from WFCO, model WF-8855.
From the WFCO web site I took a look at the trouble shooting flowchart, (
https://wfcoelectronics.com/trouble-shooting-charts/) and seemingly the only serviceable parts are polarity fuses. Are converters known to go bad? It doesn't look too hard to replace, and Amazon has the exact same one for $145. Should I cut the chase and replace it right away?
Thanks,
Maurice
