Old 09-15-2015, 04:25 PM   #1
12V Battery Charger Hook Up
Do I need to connect my battery maintainer charger directly to the battery or can i connect it anywhere in the system as long as the wire is able to carry the 10 amps??
Steve Ulman is offline   Reply With Quote
Old 09-15-2015, 04:30 PM   #2
mud yapster's Avatar
I'd connect straight to the battery.
2014 Palomino Columbus 3650TH
435AH 12V VMax Charge Tanks, 520 watt Monocrystilline Solar Array, Morningstar MPPT TS-60 CC,Morningstar Remote,Cotek True Sine Wave Inverter,Cotek Remote Controller,50amp Progressive Hardwire Surge Protector
2015 Dodge 3500 6.7L 4X4
2011 CanAm Commander XT 1000
mud yapster is offline   Reply With Quote
Old 09-15-2015, 05:49 PM   #3
You can wire it up anywhere in the system and it will charge your battery --- as long as it's wired correctly.
bruceatlam is offline   Reply With Quote
Old 09-24-2015, 12:55 PM   #4
The closer to the battery the better. Voltage drop is a killer in battery charging systems. I would connect directly to the battery. That is the only way the charger will provide the correct voltage to the battery during the charging sequence.
Kelly
Show Low and Rio Verde, AZ
cuernoverdesolar.wordpress.com
Klipstr is offline   Reply With Quote
battery
