12v ceiling light wiring - dimmer
I wasn't sure whether to post this in here or the Modification area, but here goes.
TT is in my sig. Really want to add a dimmer to the inside lights. I discovered late that I need access to the negative wire to isolate it from the battery for the PWM devices I have. Is there any info on where the negative ends up and if there are any other devices attached that I'd have to worry about? Are these pucks with the button even capable of PWM dimming?
I'm assuming the factory has a "standard" wiring layout they "follow."
Thanks.
'04 Dodge Ram 2500 CTD 4x4
-Edge CTS w/ hot unlock
-Goerend billet input shaft & low stall T/C
Rockwood 2509S
