Old 04-11-2017, 02:25 PM   #21
cmac7203's Avatar
Ok, got it home and put the new Trojan group 30XHS on the charger for 48 hours, let it rest for 24 hours and tested the voltage with a voltmeter @ 13.25 volts. I checked the specific gravity with a temperature compensating spec grav bulb and it is literally off the chart over 1.300...maybe 1.325? Lastly, the WFCO converter is putting out 13.75 volts. The trailer breakaway WAS disconnected. Click image for larger version
ID:	134437Click image for larger version
ID:	134438Click image for larger version
2019 Rockwood 2707WS
2009 Ram 2500 5.7/3:73
cmac7203 is offline   Reply With Quote
Old 04-11-2017, 02:25 PM   #22
cmac7203's Avatar
I have no idea why 2 photos of everything posted. [emoji51]
Old 04-11-2017, 02:51 PM   #23
I would have to guess that your WFCO is still putting out voltage and is in storage mode...AND it is kinda cold in Minnesota so the SG is high. But, on closer inspection, it also seems that you have some big bubbles stuck to the SG lever. You have to shake them off to get a valid reading.
2015 335DS
ScottBrownstein is offline   Reply With Quote
Old 04-11-2017, 02:52 PM   #24
Flybob's Avatar
Are you saying the breakaway switch was pulled?
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 04-11-2017, 03:22 PM   #25
The SG reading you posted in the image is just under 1.250
2007 Surveyor SV230
- 200 Watts Solar/MPPT Controller - 220 AH Battery Bank (Two-GC2) - 600 watt PSW Inverter - (2) 2000 watt Inverter Generators - LED Lighting
2009 F150 - 5.4 Litre with Tow Package
Boon Docking 99% of the time.
boondocking is offline   Reply With Quote
Old 04-11-2017, 03:41 PM   #26
cmac7203's Avatar
Yeah, I was reading it wrong. It is hovering between 1.225 - 1.250 across all cells after I knocked off bubbles from the lever. The SG bulb is temperature compensating. At this point I don't know what is next. The battery is NEW. A different charger maybe?
Old 04-11-2017, 03:42 PM   #27
cmac7203's Avatar
Yes, at the campsite but my wife thinks it was many long enough because I checked battery the moment I unhooked and it was already declining.
Old 04-11-2017, 03:43 PM   #28
cmac7203's Avatar
Originally Posted by Herk7769 View Post
Check to see if the fridge climate control is on.
Check to see if your tank heaters are on.
Both draw huge amps when running.
I am going to cut the heater wire and cap it with a spade connector to reconnect if needed.
Old 04-11-2017, 03:58 PM   #29
Trojans like a bulk charge of 14.8v. It is also recommended to do an initial equalization charge (16.2v) on new batteries. The low converter charge voltage is more than likely why you are getting a low SOC reading.
2007 Surveyor SV230
Old 04-11-2017, 04:03 PM   #30
cmac7203's Avatar
That matches what I just read from the Trojan site. My Genius 7200 charger nor the WFCO converter will ever get my battery where it needs to be. Man, this stuff is like alchemy! Thanks Boondocking and everyone!Click image for larger version
Old 04-11-2017, 04:32 PM   #31
Hate to use the old "watched pot" analogy, but it takes a really long time to get to 100% SOC. DOn't remember how long you waited and if the batteries were new they should have been at at least 80%. Looks like your converter is putting out 13.75 which ain't boost. This chart is from Progressive Dynamics. At least 3 days from low charge. If you have the voltage you have to have the current.
Name:	How Long to 100 Percent.png
2015 335DS
Old 04-11-2017, 04:38 PM   #32
cmac7203's Avatar
Makes sense. I gave it 48 hours on charge and 24 to stabilize. I just put it back on charge at the 14.8v (7.2a) setting. I was using 14.5v (7.2a) setting. I will let it cruise along on auto for another day to give it the 3 you recommend, and then allow another day to stabilize before rechecking with my temperature compensating hydrometer. I should probably think about purchasing a more robust charger...7.2A is pretty lame. [emoji51]
Old 04-11-2017, 05:13 PM   #33
7.2A will get you there @ 14.8v, it just takes a while.
2007 Surveyor SV230
Old 04-25-2017, 10:59 PM   #34
cmac7203's Avatar
Fixed on multiple levels. 1.) 3-day charge on Noco Genius 7200 and rested for a day. Hydrometer at 1.2775. 2.) Yanked fridge heating strip jumper. 3) Disconnect installed on positive terminal. 4.) verified charging voltage from WFCO and all are in spec. 5.) cleaned up/roughed up ground connections from battery to frame and used battery terminal spray. Good to go. Thank you everyone.
