Old 02-11-2013, 02:29 PM   #1
William
WEMig's Avatar
12V Electrical Problem
I have a 2012 Crusader 320RLT. One of the bulbs in the light fixture above the counter and sink burnt. I found the replacement (PN 1076) and put it in. The 15A fuse burnt when I put the light switch on. I checked that the light bulb was seated properly and replaced the fuse. It burnt again. I guess I could be answering my own question, but I would suspect a short in that circuit. Any recommendations welcomed. Thanks.
2011 F250 Lariat 6.7L
2016 (19 Nights Camped/1348 Miles)
2015 (38 Nights Camped/3560 Miles)
2014 (28 Nights Camped/1980 Miles)
2013 (30 Nights Camped/1411 Miles)
WEMig is offline   Reply With Quote
Old 02-11-2013, 03:21 PM   #2
Head Rambler
Does the fuse blow if you leave the lamp out?
Gotta go campin!
Old 02-11-2013, 03:26 PM   #3
William
WEMig's Avatar
No, only when I turn on the switch.
Old 02-11-2013, 03:26 PM   #4
Owner/Operator
RodeoGeorge's Avatar
If I recall, the 1076 Bulb has two contacts inside the bulb base.
The most common error is to use something like a 1141 Bulb (Used in most fistures except wall aconces and hanging lights which require a wired ground) that has a single contact. That single contact shorts the two 1076 contacts.
Ensure that your bulb has the two contacts to match the fixture.
RodeoGeorge
RodeoGeorge is offline   Reply With Quote
Old 02-11-2013, 03:30 PM   #5
William
WEMig's Avatar
It has 2 contacts. What's funny is that the other fixture beside it (same type fixture) has a single contact. I will have to check inside the fixture when I get home to see what type of contacts it has. Just puzzling because its worked fine since it was new.
Old 02-11-2013, 03:31 PM   #6
Herk7769's Avatar
Sounds like the wrong bulb is shorting out the fixture.
HAM CALLSIGN - KC3FFW
Old 02-18-2013, 10:38 AM   #7
William
WEMig's Avatar
UPDATE. Found the problem which is perplexing. The other light fixture on that curcuit identicle to the one with the burnt bulb had a different light bulb in it. It was a single contact bulb in a double pole light fixture. I replaced that bulb with a double contact bulb (1076) and it quit burning fuses. Now, that single contact bulb has been in the fixture since it was new. How did it work without burning fuses to this point, I do not know.
Old 02-18-2013, 11:02 AM   #8
SYE
SYE's Avatar
It was probably using the ground from the socket, and the other was only touching one of the contacts is probably why it worked, then it finally moved enough to make contact with both then it started blowing the fuse.
Scott & Vicki
2018 Silverado 3500HD Dually 6.6L Duramax/Allison
2018 Columbus 366RL 1492 Edition
Camped 2012 19, 2013 110, 2014 129, 2015 97
2016 93, 2017 79, 12 Nights Camped 2018 57 nights reserved
SYE is offline   Reply With Quote
12 Volt
