Old 03-26-2014, 05:25 PM   #11
RPAspey's Avatar
Originally Posted by T- High View Post
20 bulbs over one years time, I'm a full timer so I use the lights every night. It's a 2013 model, and I have not checked the voltage. The bulbs have 2 contacts.
Voltage won't make much of a difference, unless its extremely high.
I'm going to go out on a limb here by saying you regularly use both bulbs in the fixture and that those fixtures get hot. That heat will lower the already short expected lifespan. Then, if you travel a lot, the vibration breaks the already weakened filament.
2000 Cherokee 31BH, "flipped axles and raised",LEDs, solar, inverter, etc..aka "boondock ready". '07 Tundra 5.7L DC-LB, modded as well.
2000 Cherokee 29BH with 6V batteries, LED lights & 400 watts of solar power, flipped axles and raised. 2007 Tundra 5.7L DC-LB with lots of mods. C-co, 8/158th AVN Maint.
RPAspey is offline   Reply With Quote
Old 03-26-2014, 05:29 PM   #12
fonzie's Avatar
Yes I'll second that......
Fonzie
Old 03-26-2014, 06:21 PM   #13
Originally Posted by Dave_Monica View Post
Is this high usage on a particular fixture...not too many fixtures that would be using a 1076 bulb.
Dave
Yes, over my island, and over my dinner table. That's the only lights that uses the 1076 bulbs.Both lights under the cabinet by the stove have stopped working and one over head light in the living area has quit working( burnt out ) also the reading lights over the recliners have stopped working, one at a time. Don't get me wrong, I am a fool about my Sandpiper, it's the nicest RV I've ever owned. Just wanted to see if any one else had the same problem.
T- High is offline   Reply With Quote
Old 03-27-2014, 07:07 AM   #14
cpaulsen's Avatar
Buy some 1156 LED bulbs
cpaulsen is offline   Reply With Quote
light
