Old 03-26-2014, 10:29 AM   #1
12v Lights in my 35ROK
I have went thru 20 12v light bulbs (1076) and now have 7 lights out in my RV. Any one else having this problem?
T- High is offline   Reply With Quote
Old 03-26-2014, 10:31 AM   #2
fonzie's Avatar
What is the voltage at your battery using a dc voltmeter? Is this the bulb you are using? double contact? as in the link below or bulb has only one contact?
http://www.oreillyauto.com/site/c/de...1566&ppt=C0010
Fonzie
Old 03-26-2014, 10:48 AM   #3
TURBS's Avatar
Im surpised it has a 1076 bulb "old school"
Most new units have 921 or 912 or led of course.
TURBS
Sabre owners united!
Old 03-26-2014, 11:05 AM   #4
Brian and Michele's Avatar
We have a 35ROK and have replaced two or three over the kitchen island but not much else.
Brian
You can follow our camping adventures here
Brian & Michele
Our Blog
Truck: Dodge D3500 1 Ton Dully Diesel
Camper: 2014 Sandpiper 35ROK
Nights Camped in 2012 (truck camper) 16
Nights Camped in 2013 48
Brian and Michele is offline   Reply With Quote
Old 03-26-2014, 11:30 AM   #5
RPAspey's Avatar
Ok, 20 bulbs over how much time? Those bulbs "burn" hot and don't have a long lifespan (as in only 200 hours)..
.so if you tend to leave them on for long periods at a time, they won't last. Also, cheap bulbs won't have a good lifespan either.
Might be a case for LEDs.
2000 Cherokee 31BH, "flipped axles and raised",LEDs, solar, inverter, etc..aka "boondock ready". '07 Tundra 5.7L DC-LB, modded as well.
2000 Cherokee 29BH with 6V batteries, LED lights & 400 watts of solar power, flipped axles and raised. 2007 Tundra 5.7L DC-LB with lots of mods. C-co, 8/158th AVN Maint.
RPAspey is offline   Reply With Quote
Old 03-26-2014, 03:53 PM   #6
12v lights
20 bulbs over one years time, I'm a full timer so I use the lights every night. It's a 2013 model, and I have not checked the voltage. The bulbs have 2 contacts.
Old 03-26-2014, 03:59 PM   #7
Dave_Monica's Avatar
Is this high usage on a particular fixture...not too many fixtures that would be using a 1076 bulb.
Dave
Old 03-26-2014, 04:14 PM   #8
fonzie's Avatar
Does the fixture has two contacts also or single? I'm asking because same bulbs will fit in single and two contact fixtures and create issues.
Fonzie
Old 03-26-2014, 04:26 PM   #9
I thought that the bulbs with 2 contacts on the bottom have pins on the sides that are the same and single contact bulbs have offset pins so they're not interchangeable.
Dave
Old 03-26-2014, 04:33 PM   #10
fonzie's Avatar
Dave
Yes you are correct, forget my last post.
Fonzie
light
