Old 09-03-2013, 02:19 PM   #1
Question 12v load causes A/C to trip circuit breaker
I have not seen this particular problem in the existing posts.
2006 FR Trailer with WF8955 board. If there is a load on the 12v, such as the ceiling fan with A/C running, the A/C circuit breaker pops.
I have downloaded the converter guides on this sight (thanks for posting) but would appreciate any other guidance. Other info:
New battery
New thermostat
12v lights dim after only a couple of hours
Propane detector beeps low voltage at times
Have not heard converter fan come on since this started
Thanks for any guidance.
Paniculata is offline   Reply With Quote
Old 09-03-2013, 05:03 PM   #2
Dave_Monica's Avatar
Sounds like your convertor isn't working at all and allowing the battery to discharge. I know that you need 12V for the control boards for the fridge and furnace...guess I can add A/C to that list too.
Dave
Old 09-03-2013, 05:10 PM   #3
Denver, CO
garbonz's Avatar
What circuit breaker? the AC or the main. Ceiling fan is 110v not 12. Roof vents are 12volt though. I don't think anything in the AC unit is 12 volt from the camper battery, there isn't even any 12 wires to them, I don't think
Sounds like time for a Progressive Industries converter.
2017 Fuse 23T
Old 09-03-2013, 09:19 PM   #4
That would be Progressive Dynamics.
Old 09-04-2013, 06:45 AM   #5
TURBS's Avatar
Fyi my ceiling fan is 12 volt.
There's no reason why his can't be as well.
Op
I would also recommend a progressive dynamics brands converter.
You DO NOT need to replace the whole panel.
Here's dead one being removed on a wfco which is most likely what u have and there junk.
Turbs
breaker
