Old 04-08-2013, 01:30 PM   #1
12V not working...viewable fuses all good
We had 12V lights etc. working until we plugged into 110/120..after about 30 minutes, everything went out that you normally could use on 12v only. we have looked at fuses. We have a 2001 Forest River Cardinal 5th wheel with 2 slides. Got any ideas what to check next? We just bought it used, previous owner had no issues with it.
Is there a hidden reset or hidden fuse someplace?
webemimipop is offline   Reply With Quote
Old 04-08-2013, 01:37 PM   #2
TURBS's Avatar
Look by your battery as there may be a resetable curcuit breaker such as this one.
There may even be one up in the pin box junction box.
Turbs
If you don't have a digital volt/ohm meter now would be the time to invest in one for your camper.
Old 04-08-2013, 01:58 PM   #3
I failed to mention that there are also solar panels and a Freedom inverter/converter system. It is charging, the panel shows full battery charge. We could even run a vacuum cleaner and the microwave (didn't try at the same time) without the trailer being plugged in.
Old 04-08-2013, 02:15 PM   #4
TURBS's Avatar
Have you looked for the breaker yet?
Old 04-08-2013, 02:23 PM   #5
wmtire's Avatar
Is anything that runs off 110/120 working?
I know this is may sound dumb, but what did you exactly plug into? We have had instances of where other members plugged into something wired wrong, and it took a little bit before their trailer quit working......and their converter fried.
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
Old 04-08-2013, 03:42 PM   #6
yes..The TV, microwave, ceiling fan, and plug outlets.
Old 04-08-2013, 03:44 PM   #7
I did look for the resetable circuit breaker and didn't see one. I noted in another reply that there is a inverter/converter near the batteries.
Old 04-08-2013, 03:49 PM   #8
It's possible that you have the same problem that I had on my new XLR 35-12--mis-routed DC wire(s) shorting out. Here's the description that I posted several months ago:
XLR35-12 DC power failure
I wanted to update folks with an issue I encountered on my 1 month old XLR 35-12. After about 1,000 miles on the new RV, we lost all DC power while camping. Of course, the slides were out at the time. We were in Cheyenne WY with the nearest FR dealer 60 miles away.
We had no DC power period. No battery, no converter power, nada. With no DC, we lost many systems including slide operation, hot water, DC lighting, stabilizer, struts to name a few. I tried to get someone to come fix it on site with no luck so I had to learn how to bring in my 3 slides manually. That was a steep learning curve with one hydraulic slide, one electric, and one Schwintek but I did it.
I troubleshot everything I could with my voltmeter (I'm pretty handy) to no avail. I finally decided the converter was bad but it bench tested good outside the RV. When installed, the converter showed an overload condition.
I hauled the RV to the nearest FR dealer for warranty repair. The dealer in Evans CO was super! His tech worked on the trailer for 6 hours troubleshooting before he found the problem. Some "genius" on the FR line routed critical DC wires between the DC bus and the fuse panel poorly. These wires (2-3 of them) were routed between the RV skin and the frame structure. After 1,000 miles of bumps, the wires chaffed and grounded to the frame, killing my DC.
I'm posting this to help others who may find similar problems. I pick up my repaired RV tomorrow after only 1 day in the shop. Many thanks to Great Outdoors RV in Evans CO!
Dan
F-350 Dually
Cedar Creek Silverback
Mazda Miata TOAD for sex appeal
danno2u is offline   Reply With Quote
Old 04-08-2013, 03:50 PM   #9
TURBS's Avatar
Is your battery dead?
Old 04-08-2013, 03:58 PM   #10
no..there are actually 4 batteries in it but they are not dead.
