Old 06-24-2018, 08:30 AM   #11
wmtire's Avatar
Originally Posted by cavie View Post
Check your "converter" volt 120 circuit breaker. Check your TWO 30 or 40 reverse polarity fuses. They are side by side on the converter.
Your converter is what provides power to your 12 volt DC items in the RV, when connected to shore power/generator. If you are not connected to shore power/generator, then your battery provides this 12 volt DC power alone...up until it runs out of power/depletes.
Converter or Inverter (they are different)
If your battery is depleted, it cannot provide the power "IF" the converter is also not functioning when connected to shore power/generator.
I would also suggest checking to make sure the converter is operating by either making sure it's circuit breaker is not tripped and/or the reverse polarity fuses (up to 3 total) are not blown. These reverse polarity fuses are there to protect the converters electronics should you connect a battery backwards, but we have also seen them blow when there is an inrush of current from the converter trying to recharge a depleted/bad/faulty battery sometimes. The converter is also a battery recharger when connected to shore power/generator.
As Cavie pointed out, these fuses "can" be on the converter., but many are also in the RV's distribution panel..depending on make/model. See pics below:
2011 Flagstaff 831 RLBSS
Never Apologize! Never Explain!
Sorry, thatís my motto.
Old 06-24-2018, 08:45 AM   #12
bigt1739's Avatar
Thanks! Iím getting ready to head home, Iíll really bite into this week
bigt1739 is offline   Reply With Quote
Old 06-25-2018, 10:02 AM   #13
bigt1739's Avatar
All fuses and breaker are good. The converter puts out 1 V..measured right on the lugs on the converter itself...assuming bad converter?
Old 06-25-2018, 01:29 PM   #14
wmtire's Avatar
The converter inputs 120 volt AC and outputs 12 volt DC.
Just to be sure, which kind of voltage do you have the multimeter set to measure, if it's not an autoranging type multimeter
Old 06-25-2018, 01:31 PM   #15
bigt1739's Avatar
Autoranging...120v AC in for sure....1v DC out for sure.
Old 06-25-2018, 01:52 PM   #16
rk06382's Avatar
Remove the negative wire from the converter & remeasure output of the converter. If you still get 1v DC with no load, then your converter maybe bad.
Robert
2018 FR3 28DS
Samlex EVO-2212 Inverter/Charger | 400ah Battle Born LiFePO4 | Victron BMV-712 & MPPT 100/50 | 800W Renogy Solar | Fan-Tastic Fans | Blue Ox TruCenter | Dometic 320 | SnapPads
Retired: Alaska Army NG
rk06382 is offline   Reply With Quote
Old 06-30-2018, 12:53 PM   #17
bigt1739's Avatar
I just installed the new converter, it was actually pretty easy to do!!....everything is working great now....thanks for the help
power
