Old 10-21-2018, 05:06 PM   #1
12v powerless
I have a 2017 wolf pup limited and had a power surge. Now no interior lights work, radio no work and water pump no work. Bath fan works, awning control works. When on 110, ac fine, microwave fine, tv fine. Power cord (furrion) all leds out and at camper also. Please, any clues?
JD54 is offline   Reply With Quote
Old 10-21-2018, 05:19 PM   #2
A32Deuce's Avatar
Check your 12 volt fuses, including the ones to protect the converter.
A32Deuce is online now   Reply With Quote
Old 10-21-2018, 05:46 PM   #3
cavie's Avatar
Bath fan and awning are 12 volt so some 12 volt is working. Check ALL your 12 volt fuses with a meter. Don't just look at them.
2002 27rk Wildcat 5er.
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
cavie is online now   Reply With Quote
Old 10-21-2018, 07:35 PM   #4
I've check all fuses and breakers in distribution panel. Reset all breakers and pulled each fuse to check. I also checked fuse for water pump and all looks good. It seems battery isn't charging when connect to 30 amp box on house and also appears that camper not receiving power from battery. No lights when connected or on battery. Tried to rest relay underneath by battery. Odd thing is, bath fan and awning work, but nothing else. A real head scratcher here. Ty
Old 10-21-2018, 07:57 PM   #5
The power inverter/convertor may have a reset switch.
JS Stanley is offline   Reply With Quote
Old 10-21-2018, 10:55 PM   #6
bikendan's Avatar
Could have tripped the 12v resettable circuit breaker that has a tiny black reset button.
On TTs, it's usually tucked along the A-frame.
Equalizer WDH
Old 10-21-2018, 11:46 PM   #7
cavie's Avatar
OP has 12 volt fan and awning.
Old 10-22-2018, 08:00 AM   #8
A32Deuce's Avatar
Are they all wired the same?
Old 10-22-2018, 04:29 PM   #9
A power surge would have taken out fuses before it affects wiring or end of circuit devices 99.99% of the time - that's what the fuses are for. You have some 12V power - some circuits work, some don't. Again, points to fuses. Looking at them is insufficient; you must check resistance or conductivity with a meter/tester.
just my experiences
Fred W
Old 10-24-2018, 04:39 PM   #10
cavie's Avatar
just my experiences
Fred W
Fuses do not protect from power surges. Fuses protect from wires over heating and starting fires and protect from to much amperage on the wire. That is all a fuse is intended to do. A large power spike can get right past a fuse and distroy electronic equipment. Surge protectors protect from high voltage power strikes and nothing more.
power
