Old 05-21-2013, 06:53 PM   #1
12v Problems
Surveyor sv180t
WF Converter
On the way home from a trip, lost 12v power
Hooked up to shore power, no problems.
Battery tested good, putting out 13
Checked fuses, tripped breakers, still no power when not connected to shore.
No voltage reading at terminal where the battery wires come into the WC converter.
Next step?
Thank you for any advice before I have to haul it in to a repair shop
Desmo13 is offline   Reply With Quote
Old 05-21-2013, 07:06 PM   #2
wmtire's Avatar
There is usually a fuse (sometimes a resettable type circuit breaker) between the battery and converter. You'll need to look along your frame rail to find it, if nobody else chimes in with a location.
2011 Flagstaff 831 RLBSS
I’ve lost my scapegoat.
Old 05-21-2013, 07:09 PM   #3
TURBS's Avatar
Originally Posted by wmtire View Post
There is usually a fuse (sometimes a resettable type) between the battery and converter. You'll need to look along your frame rail to find it, if nobody else chimes in with a location.
X2
Old 05-21-2013, 07:13 PM   #4
crunchman12001's Avatar
X2 Make sure to check wires in that box for lose connections. Also, check wires at battery disconnect switch if equipped. My ground wire came out of the eyelet when I bumped the wires. Nice and tight now.
crunchman
2015 F-250 FX4
crunchman12001 is online now   Reply With Quote
Old 05-21-2013, 09:10 PM   #5
thank you all, I can't find the inline fuse. the bottom of my trailer has a cover, probably under there? anyone know.
Old 05-21-2013, 09:15 PM   #6
wmtire's Avatar
EDIT: I see your trailer model now in the opening post
Did you see anything that looked similar to this?
Old 05-21-2013, 09:35 PM   #7
DDC
DDC's Avatar
Test lite from pos term. to the frame to test the ground from the battery.If you don't have a test lite get one jumper cable connect to neg term. then connect the other end to the frame and check interior lights. The ground is the most common problem in 12 volt faults.
Cedar Creek Silverback 33IK
Donald&Casey cairn terrier
DDC is offline   Reply With Quote
Old 05-21-2013, 11:25 PM   #8
bikendan's Avatar
the resettable fuse that WMTire posted a pic of, is along the A-frame, not in the bottom of your trailer.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 05-24-2013, 11:07 PM   #9
Problem solved, the first thing I should have checked. Rust/corrosion on the battery ground wire connection. I still never fund the inline fuse though
