Old 11-09-2013, 08:06 AM   #1
Dovetail's Avatar
12V system question
Went to storage facility and tried to bump out slide. Battery dead. My fault, had mot disconnected battery.
Hooked up the trailer cord to the truck and trailer still dead.
Does the truck only charge the trailer battery?
Or does it supply power to the 12v system.
I only left it connected for a couple of minutes. Had i waited a while would it have mattered?
and did not have the hitch connected. Would it be lack of ground?
Never had to place in storage before, but new house has no place for the trailer.
Thought i could just plug it into the truck and i would have power for the landing gear, but now am a little worried.
Rick and Linda, Lindale, TX
2011 Flagstaff 8528 CKSS
2006 F350 SW
Camping nights 2013: 130
Camping nights 2014: 17
Dovetail is offline   Reply With Quote
Old 11-09-2013, 08:15 AM   #2
Rrickim63's Avatar
It will take more than a few minutes to recharge. I would suggest removing battery and charge it at home.
2006 Roo 23B hybrid
2006 Ford F150 4.6L
Rrickim63 is offline   Reply With Quote
Old 11-09-2013, 08:18 AM   #3
PhoneDude 8289's Avatar
I believe that the cord from truck to RV has a ground in it. I don't think the wiring is heavy enough to carry enough power for the slides or landing gear, a battery with a good charge in it will be required. It would take quite a while to charge the RV battery from dead to be able to operate slides / landing gear plugged into the truck.
Joe & Beverly
2014 Ram CTD, CC, SB
2014 8289WS lifted
PhoneDude 8289 is offline   Reply With Quote
Old 11-09-2013, 08:18 AM   #4
Hooking the trailer up shouldn't make any difference as the plug has a ground wire in it. The truck/tow vehicle should have charged the battery(s) if you had left it hooked for a while unless the trailer battery(s) are completely dead. If they're dead, you will have to replace them.
Old 11-09-2013, 08:19 AM   #5
Professional Texan
TexasBob's Avatar
Your truck only charges the battery.
Your trailer plug should provide a ground.
Basics:
My truck has to be running to charge the battery.
If your battery is completely dead it may take a while for your truck to charge the battery.
Worse case: Your battery could be so flat and damaged that it will not take a charge.
Texas Bob
2015 Chevrolet Silverado HD2500 Z71
2013 Prime Time Tracer Executive 2640 RLS
TexasBob is offline   Reply With Quote
Old 11-09-2013, 08:29 AM   #6
fonzie's Avatar
You can either remove battery and bring home and recharge, hook up trailer cord to truck and wait 30 minutes at least with truck running (maybe will do it) or use booster cables from truck to trailer battery with engine running.......always use safe boosting procedure.
Fonzie
Old 11-09-2013, 08:30 AM   #7
Fulltime family RVer
I've done just what you expected to happen- plugged the trailer into the camper so that I could run the slides in/out. I had left the truck running and waited for a few minutes.
ependydad is online now   Reply With Quote
Old 11-09-2013, 09:10 AM   #8
Denver, CO
garbonz's Avatar
If the battery in your camper has been sitting dead for awhile, It is likely not going to be much good. Might as well take it home and charge and test it out. This is a good link for a procedure to evaluate deep cycle batteries.
Pacific Power Batteries - About Automotive Batteries
2017 Fuse 23T
Old 11-10-2013, 07:22 AM   #9
Dovetail's Avatar
Thanks to all for responses. Brought the battery home and charged it. Glad i went out to the trailer and discovered this before i planned on using it.
Will disconnect in the future and maybe find a discinnect switch for it.
Now i know.
2006 F350 SW
