02-14-2018, 04:00 PM
12volt battery of Rockwood
Is the 2018 Forest River Rockwood 2902 WS equipped with a way to keep and recharge the 12volt battery thats on the tongue hitch? One person told me it was equipped with a charger that recharges the battery when a have camper is plugged in 50amp service. Another person told me that it doesn't come with a charger and I would to buy a battery charger to recharger the battery. I'm new to Forest River so any suggestions will help....
02-14-2018, 04:18 PM
Yes, it charges the battery when the rig is connected to power. FYI, some rigs have a battery disconnect. You'll have to make sure that isn't disconnected for it to charge. Easy way to know is to see if your interior lights work when not connected to AC power. If not, you need to check that disconnect switch. All of the Rockwood's I've seen use a push/pull type switch with a chrome knob- usually located by the interior fuse panel-which is also the converter that charges the battery, btw.
02-14-2018, 04:35 PM
Thanks, I see a big red switch on the inside of the tongue hitch that has "Battery Disconnect" written on it. I guessing is the switch that you mentioned. It has a red turn knob on it.
02-14-2018, 04:45 PM
AKA: 'tiredTeacher
Aha! A used trailer, right? The previous owner (PO) added that. Depending on how many modifications (mods) the PO did, you could be in for interesting discoveries as you go along.
Wright and Penny
(with Fitz and Lizzie, the camping kitties)
Richmond, Va.
2010 Tundra 4X4 5.7L V8
2014 Rockwood 2604WS
Life is a cruel teacher. She gives the test first; the lesson then follows.
02-14-2018, 04:50 PM
No.... We brought it brand new. The red switch is on the inside the tongue hitch tucked up under the gas bottles... Maybe its the switch for the electric jack on the front. If so I will look harder for it on the inside.
02-14-2018, 04:54 PM
That is the disconnect switch, my '18 2509S has the same one. As long as it is on and you are plugged in the camper has a converter that will charge it up.
02-14-2018, 05:39 PM
To charge (from camper convertor) your battery, you do not really 'need' a 50 Amp out side power source. Get a 'step down' 'pig tail', for a 110v if you are close to a 'house' power source. You can not 'run' the
AC or micro wave oven as this will cause a breaker trip.
https://www.amazon.com/Proline-Power...igtail+adapter
Brother Les
02-14-2018, 05:42 PM
Dealer should know if it has a battery disconnect...
It is easy to tell if it goes to the switch/jack/battery or under unit/battery/switch.
Brother Les
02-14-2018, 06:03 PM
Battery Disconnect
That's where Forest River installed my disconnect.
2015 Shamrock 23IKSS, Oyster shell
2019 Chev Silverado LT Z71 Ext. Cab, 4x4, 5.3L V/8
Reese Straight Line WDH, 2000W Honda Gen.
2 Old Town kayaks & 2 Boston Terriers - Zoey/Gonzo
Lar & Ruth
02-14-2018, 06:22 PM
All RVs have Converters, which have a battery charging feature when plugged into shore power. It is inside the trailer, usually behind the fuse/breaker panel.
I'm sorry you got such a lousy PDI from the dealer.
Stuff like that should be part of a good PDI.
02-14-2018, 11:54 PM
Just as confused as you
Sorry, I'm late to the party. If you need help understanding the electrical or your RV then check out the info gathered by wmtire. The links are below. I added the link for "The 12 Volt Side of Life" to the list. Read what interests you but I suggest you check out all of them.
The “12 Volt Side of Life” file is on Forest River Forums in the Library > Power and Electrical section in the light green bar at the top of the page and is a download and is found here. Forest River Forums - Downloads - 12 volt side of Life
The links below were compiled by another member of FRF.
Disclaimer: These links and articles were compiled by wmtire. He is a site team member of forestriverforums (FRF). If you give thanks, then give it to him. I had nothing to do with gathering the information, I’m just passing it along.
“I always recommend these following links to newer RV owners. It explains a RV's different electrical systems, as well as what works off of 120 volt AC vs. 12 volt DC. Not knowing your RV experience, The below is a copy and paste, and I usually recommend it to those just starting out. Some of it, you may already know, or may not be applicable to your particular RV. You will be able to filter out what pertains to your situation or not. I would suggest you read the electric threads and energy management first, and then the converter thread. This will help explain your different electrical systems of your RV, and how they operate...as well as what the converter does. The very first link will explain what operates off what system.” - wmtire
Basic electric:
Basic RV Electricity - RV Information (RV Maintenance)
https://www.rvtechmag.com/electrical/chapter3.php
RV Electric
Your very important converter:
RV Converters and Amp Draw - RV Information (RV Maintenance)
Inverters and residential refrigerators in RV's:
http://rveducation101.com/articles/rvinverters.pdf
More reading so you understand the different electrical systems of your RV.
Installing a dedicated 30 amp RV outlet at home:
How to wire a RV 30 amp outlet
Suburban water heater (if applicable to your RV):
Suburban's electric switch and much more
Suburban Water Heater Video Guides
Water Heater bypass/crossover valves:
NO (OR LUKEWARM) HOT WATER -Please read first
And the newest additions to help understand what constitutes a true full cylinder in refilling vs exchanging propane cylinders... as well as how the automatic propane changeover regulator works:
Propane Cylinders (Refilling vs Exchanging)
Propane automatic changeover regulator
Richard & Jill
02-16-2018, 02:32 PM
Battery disconnect switch
My new 2503S has the switch mounted in front under the propane tanks. It’s big and red. I put it in the disconnect position when stored on my driveway. I take the battery out and put on a charger on my work bench. The day before I head out I put the battery back in, connect to 110 volts AC, turn the big red switch on and then turn the fridge on to get it cold. If you leave the battery in you should use the switch to disconnect the battery as the gas sensors will eventually run the battery down. One other thing, your slide should work OK if plugged into shore power with the battery disconnected. Mine does but it’s a small slide.
_________________
2018 2503S Mini-Lite
2017 Tundra Long Bed Double Cab
02-17-2018, 08:52 PM
FR has been using those for the last few years instead of the push/pull switches. If it's like mine, the red "key" will come completely out of the socket and hang by a cable when in the disconnect position. To connect, you just line up the pin and push it in while turning.
