Old 06-07-2009, 01:00 PM   #1
Cool 15 AMP Fuse for SV263
We tried out our SV263 for the first time and found that one of the 15 AMP fuses is blown and every one we put in blows. The fuse controls the light over the sink, the stove fan, the outlet on the back of the dinette and the light over the table. The TT is stored in Powhattan and our dealer is in Mechanicsville, so we are trying to figure out how to fix it without having to make that trip for something which may be very simple. Any ideas?
VAlover is offline   Reply With Quote
Old 06-07-2009, 01:51 PM   #2
cat1956's Avatar
Does it blow with all the switches off ?
cat1956 is offline   Reply With Quote
Old 06-07-2009, 08:11 PM   #3
NWJeeper's Avatar
So is it a 15amp DC automotive type of fuse or the 15amp 110V AC breaker that is blowing? Reason I ask is that "the outlet on the back of the dinette" is a standard 110V outlet correct? IF so then you are talking about 2 different circuits AC and DC which doesn't make any sense.
Ed & Wendy
www.nwjeepn.com
Old 06-08-2009, 07:40 AM   #4
Yes. After blowing several fuses, we double checked to make sure all switches were off.
Old 06-08-2009, 08:13 AM   #5
You are right - it doesn't make any sense. I think we will take it in. It is the 15amp automotive type of fuse that is blowing. I'm thinking it is possible we nicked a wire when inserting a bolt for the curtain, or the bolt is hitting against a wire.
Old 06-08-2009, 08:19 PM   #6
Knower of Some Things
Very possible. Unfortunately, it's a PITA to diagnose. I've gone as far as pulling one screw at a time until the problem went away. I also use the auto reset fuses to diagnose the problem, as it gets real expensive to keep replacing the fuses. You can also use a battery charger and watch for sparks, or the simple volt-ohm meter.
PumaPro is offline   Reply With Quote
Old 06-19-2009, 12:22 PM   #7
Talking 15 AMP issue resolved
The dealer found our problem right away. We had installed a space saver coffee pot under a cabinet by the sink. You guessed it - we cut a wire in the process. If we had wanted to find the wire, we probably never would have. Who knew there was an important wire running through the bottom of a cabinet! So much for our modifications. We are now ready for vacation.
Don and Laura + Roo
Chesapeake, VA
Old 06-19-2009, 12:48 PM   #8
cat1956's Avatar
Glad you got it fixed.
