Old 04-06-2016, 11:14 AM   #11
Some guy in back...
Originally Posted by mfMcFroggierPod View Post
Solder makes your best connection.
Sorry, but "Best" and solder and electrical connections can be looked at a number of ways. I look at it differently.
In industry, very, very, few large gage cable terminations are done using solder. Soldering a termination is highly dependent on several variables that need to be controlled with the biggest one being the skill, training and motivation of the human doing the soldering. The may not fully apply to a personal/casual/hobby activity like RV mods done by the owner or a buddy but it is still a significant variable.
Soldering is not always the best and can all to often result in joints that look good but result in damaged insulation from heat, wicked solder that results in a long, mechanically problematic connection, no true mechanical bond between the connector and the cable and personal exposure to toxic fumes.
from my perspective, crimping is the way to go for wire/cable terminations.
Cheers!
ChateauV10
SF Bay Area
'99 Ford E350 V10
'16 Rockwood 8329SS
ChateauV10 is offline   Reply With Quote
Old 04-06-2016, 11:20 AM   #12
Originally Posted by ChateauV10 View Post
Sorry, but "Best" and solder and electrical connections can be looked at a number of ways. I look at it differently......
True, you have to know about these things, as well as have experience soldering. However, the same can be said of crimping with substandard tools or incomplete solutions.
Rosin core solder is quite safe and these cables are so big that they take to it quite well. Of course...heat the lug and not the cable and the lugs are really big as well. But then I have soldered a lot of things in the past.
2015 335DS
ScottBrownstein is offline   Reply With Quote
Old 04-06-2016, 01:07 PM   #13
Swampy's Avatar
Our utility crews use a Burndy tool MRC840 Burndy HYTOOL Rotating Die Crimp Tool, #8 - 4/0 AWG, Cu. A bit pricy, but made for the task.
............. Swampy
Swampy is offline   Reply With Quote
Old 04-06-2016, 01:14 PM   #14
Too Tall's Avatar
Do both, crimp and solder.
Rockwood 2104S, 2014 Ram 2500 Diesel.
USMC 68 -70
Too Tall is offline   Reply With Quote
Old 04-06-2016, 01:15 PM   #15
k52412's Avatar
Here is a possible solution:
Straight Barrel Fusion Battery Terminals - Positive
Terminals and lugs already loaded with solder.
k52412 is offline   Reply With Quote
Old 04-06-2016, 02:11 PM   #16
f5moab's Avatar
Check the local auto parts door. When I replaced the cable terminals on my Hummer years ago, the local auto parts store rented me the tool for a few hours for five bucks.
f5moab is offline   Reply With Quote
Old 04-06-2016, 02:18 PM   #17
GeeDubb's Avatar
I bought one of these TEMCo Hydraulic Cable Lug Crimper TH0006 - 5 US TON 12 AWG to 00 (2/0) Electrical Terminal Cable Wire Tool Kit 5 YEAR WARRANTY through amazon. But I had a lot of terminals to crimp.
gw
GeeDubb is offline   Reply With Quote
Old 04-06-2016, 02:19 PM   #18
Some guy in back...
Scott, I think both of us have soldered a lot of things in the past. I started in 1964 and I'm not old enough for Social Security (yet)!
And that is it. If you have experience and patience and a bit of knowledge, it can work out ok. BUT: decent tools and a little bit of technique allow almost anybody to make a great crimped joint!
ChateauV10
SF Bay Area
'99 Ford E350 V10
'16 Rockwood 8329SS
Old 04-06-2016, 03:09 PM   #19
I us this this hydraulic crimper from Amazon: Robot Check
For $40 it works great for the home handyman. I don't think it would hold up to daily use.
2015 Solaire 201SS
2015 GMC 2500HD Duramax
PSU Turf is offline   Reply With Quote
Old 04-06-2016, 03:18 PM   #20
Might check with an Industrial electrical contractor to make the crimps if it is a one time deal.
Harkerr is offline   Reply With Quote
