Old 05-25-2014, 09:37 PM   #11
1sgbruce's Avatar
I appreciate all the helpfully comments but we have tried everything under the sun and it seems that unfortunately we have to bring it back to the dealer to take care of this outlet issue among a few other small items that I guess come with buying a new camper.
1sgbruce is offline   Reply With Quote
Old 05-25-2014, 10:11 PM   #12
If you have an inverter it might have tripped the GF on top of the inverter. This will only control a few outlets. Its a small rocker type of reset.
Old 05-25-2014, 11:57 PM   #13
Is the 30 amp 110 volt plug? Will have 2 blades and 1 round for ground. (1hot, 1 nutural, and 1 ground) If so you are not feeding but half of the breakers in the unit as the 50 is 220 volt outlet. (2 hots, 1 nutural, and 1 ground)
In layman's terms you have two hots in a 50 amps cord and only one in the 30 amp cord.
Sent from my SCH-I545 using Forest River Forums mobile app
2007 GMC 2500 Duramax Crew Cab LB
2008 5th Wheel Cardinal 36LE
R Whitlow is offline   Reply With Quote
Old 05-26-2014, 09:51 AM   #14
1sgbruce's Avatar
Would you have any idea where the inverter would be located?
Old 05-26-2014, 09:56 AM   #15
No sorry I have a MH. Mine is located right next to the batteries and is a black odd shaped about 12" long. It is most likely close to your house batteries and I would guess its a Magnum brand.
Old 05-26-2014, 10:18 AM   #16
VinceU's Avatar
The job of the "dog bone " is to convert incoming single phase to output two common phases for your 50 amp bus. Every thing gets power that way.
