2014 Solera Brake light turn signal not working
2014 Solera 24s left side (driver's) turn signal and brake light not working. Removed sections of the bargman 47-84-009 light module and swapped with those on the right side. The light modules work fine. Fuse diagram for Sprinter does not show separate fuses for right and left but I suspect that the lights have been modified. Cannot locate fuses. Some have posted that they are in the sewer compartment, but I did not see any panel there. Can anyone tell me where the fuse might be or if there might be another problem? Problem first noticed (not necessarily when it started) after trying to connect tow vehicle. Husband says he may have inserted connecter wrong (bad design?) Thanks
