Old 11-25-2015, 11:57 AM   #1
26rr battery
So I got a brand new 26rr and everything was working perfectly. I have it in my driveway plugged into the garage with a 30amp to 110 connection. The breaker in the garage is 20amps. I left it plugged in for the last couple days and went to move it today and when I unplugged it I had no power to the trailer at all, the electric jack, radio, lights, nothing. Had to plug it back in to hook to truck. It's a brand new battery, and it was plugged in so it should of been charging it. Am I missing something?
drb1984 is offline   Reply With Quote
Old 11-25-2015, 01:15 PM   #2
Do your lights inside the trailer work when you are plugged in to 110 vac?
The radio, microwave etc will not work unless you are plugged into 110vac.
The lights and jack operate on 12vdc (the battery). Check for a disconnect switch close to the battery, it could be turn off.
You will have no charging of the battery if the discionnect is switch off.
2007 Surveyor SV230
- 200 Watts Solar/MPPT Controller - 230 AH Battery Bank - 600 watt PSW Inverter - (2) 2000 watt Inverter Generators - LED Lighting
Boon Docking 99% of the time.
2009 F150 - 5.4 Litre - Tow Package
boondocking is offline   Reply With Quote
Old 11-25-2015, 01:17 PM   #3
Pickin' & Campin'
See replies in your other post.
This is a double post.
Days Camped: '15=22 '16=46 '17=30 '18=4
battery
