Old 08-09-2015, 12:07 AM   #1
30/50 amp
Ok I gave a realy newbie question, thats been answered before.
Our TT has 30 amp service, my question is can I plug into a 50 amp service, with the proper adapter? Is there.any advantage to doing
Also is there one brand of surge protector, you folks would recommend?
maxjr758 is offline   Reply With Quote
Old 08-09-2015, 12:14 AM   #2
iceblaze580's Avatar
You will be ok plugging in your 30 amp rig in to a 50 amp plug camco has a 30 amp female to 50 amp male dog bone you still won't be able to pull more than 30 amps
iceblaze580 is offline   Reply With Quote
Old 08-09-2015, 12:32 AM   #3
2007 WildCat 32QBBS
05CrewDually's Avatar
Here's some info.
CG 20amp or 50amp
05CrewDually is offline   Reply With Quote
Old 08-09-2015, 06:49 AM   #4
waiter21's Avatar
I carry a 30 to 50 adapter, and use it occasionally.
1) When we pull into a parking spot, on occasion the 30 amp receptical on the pedestal is lose and doesn't seem to make a good connection. If there is a 50 amp receptical available, I then use my adapter and plug into to 50 instead.
2001 Coachmen Mirada (Ford F53 6.8L V10) - Toad 2003 Saturn Vue
It won't do MACH 2, but I can get a sandwich and take a pee.
waiter21 is offline   Reply With Quote
Old 08-09-2015, 10:19 AM   #5
jk510's Avatar
Back when I had a 30 amp TT I found the the 50 amp receptacles at campgrounds were in better shape than the 30 amp. I think that is because the 30 amps are used and abused more than the 50s.
Joel K
Southeast AZ
2013 Coachman Mirada 29DSSE
jk510 is offline   Reply With Quote
Old 08-09-2015, 10:33 AM   #6
Cypressloser's Avatar
Location: Alberta - East of the Rockies, West of the Rest
You will be absolutely 'aok' with the proper adapter. The adapter will terminate the 2nd leg (hot wire) and the breakers in your RV do the rest - no need for concern.
Almighty 2018 RAM 5500 Laramie CC
Riverstone Legacy 38RE, 960 Watt Solar, 6x6 Volt Battery Bank, Freedom SW 3012 Inv/Charger
Cypressloser is offline   Reply With Quote
Old 08-09-2015, 11:23 PM   #7
Ok thanks ! I thought that was the case, but wanted to be sure.
Any recommendations on which surge protector to steer clear of?
Old 08-10-2015, 06:08 PM   #8
Progressive industries is what a lot of us use here
305, 50 amp
