Old 04-09-2014, 09:07 AM   #1
30 amp & airconditioner
I have a crusader 295 with 50 amp service . It has the larger 15000 btu air conditioner. I am in a campsite with only 30 amp service . Can I run the air conditioner without doing harm to it or to the service ?
jeffscuda is offline   Reply With Quote
Old 04-09-2014, 09:14 AM   #2
jtstromsburg's Avatar
Yes. It should use around 14-15 amps running, and probably less. At startup, it can use much more but only for a short period. If in doubt, run the fridge and water heater on gas.
Sent by me
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
jtstromsburg is offline   Reply With Quote
Old 04-09-2014, 09:21 AM   #3
Fulltime family RVer
Yes, you can run it. Just be aware of what else is running. With our 15k AC, we can have 1 other high draw appliance running (baby bottle warmer, water heater, hair dryer, etc.). The microwave is usually OK but we can't run both of our microwaves at once.
We generally will switch our water heater to propane-only when on a 30amp site and then just try to be careful about what else is running.
ependydad is online now   Reply With Quote
Old 04-09-2014, 09:21 AM   #4
Old Enough to Know Better
gasman6674's Avatar
Also watch other electrical loads like blow dryers, curling irons and microwaves. You may need to turn your ac off to use them.
Regards
Jim & Debbie England
Do you have Gas? 2015 F350 6.2L CCLB DRW 4.30 axle. 2012 Yellowstone Ridgeline 34RLT Fifth Wheel
gasman6674 is offline   Reply With Quote
Old 04-09-2014, 09:25 AM   #5
There are worlds of TT's with 30A that have 15K A/C's. The one I recently sold and the one my in laws currently own being 2 examples. I would bet that the majority of TT's in the south that are over 25' have a 15K with 30A. You typically don't make the jump to 50A unless you have a 2nd A/C, which most TT's don't.
Old 04-09-2014, 10:05 AM   #6
I added a second 15k AC on our Sabre and have run both on 30a. I turned all other appliances to gas and turned of the converter breaker. Just to quick cool the unit for an hour or so. You'll be just fine on 30a.
Sent by me
Joel and Teresa
2016 Sabre 34TBOK
Old 04-09-2014, 10:12 AM   #7
AquaMan's Avatar
I can run both my 15k and 13.5k A/Cs, along with 2 fridges, lights, stereo, and tv, without popping the 30A pedestal breaker. Have done it a number of times.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 7
Old 04-09-2014, 10:14 AM   #8
SKnight's Avatar
Yep, you're fine. Only time you might have an issue is if you're running the microwave or similar high load device and the AC tries to start up. That start up load is pretty stout.
I monitored the voltage on mine connected to my 4500W genset through a 30A breaker and with the 15K unit running I turned the 13.5K unit on and even with the second unit starting up it only dropped to 104V for .25 of a second then returned to 114V.
So yeah, you'll be fine. If concerned you can get a plug in voltage monitor and watch it that way also.
Old 04-09-2014, 10:20 AM   #9
Sent by me
Interesting that you both have been successful with this-- we've only tried running both a time or two and each time it popped the 30amp breaker.
Old 04-09-2014, 10:56 AM   #10
Its all in the source code...
Sent by me
Joel and Teresa
2016 Sabre 34TBOK
