Closed Thread
Old 04-07-2019, 08:20 PM   #1
30 amp breaker
Why does my breaker panel have 2 30 amp breakers jumpered together? PD 4560 power center.
2014 Forester 2801QS
2010 Kia Soul
monte is offline
Old 04-07-2019, 08:36 PM   #2
Bill and Gail's Avatar
Might be for a dryer
Bill and Gail is offline
Old 04-07-2019, 08:47 PM   #3
Doesn't have a dryer. May have something to do with an inverter and residential refrigerator that was added. I have owned 3 class c (30amp) motorhomes and have not seen this set up. I don't know enough about electricity to understand why the breakers are tied together and jumpered. I have also not had a residential fridge before.
2010 Kia Soul
monte is offline
Old 04-07-2019, 08:49 PM   #4
cavie's Avatar
that has to be a split buss 50 amp panel. They must have run out of the right ones. A 30 amp panel does not need a 2 pole breaker. A 50 amp panel is split 50 amps to the right and 50 amps to the left. Thus the jumper on the 30 amp two pole.
2002 27rk Wildcat 5er.
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
cavie is offline
Old 04-07-2019, 08:50 PM   #5
cavie's Avatar
that's the main breaker. No dryer involved.
cavie is offline
Old 04-08-2019, 07:08 AM   #6
Junior Old Fart
I believe if you follow the bottom black wire out, it will go to the shore power feed. Behind the two breakers, you will find the feeder buss split between the breakers, left breaker feeds power to everything to the left, right one to the right.
LTDunltd is offline
Old 04-08-2019, 07:22 AM   #7
fonzie's Avatar
Is your Forester a 30 or 50 amp shore power supply? Also did you bought it new or used?
Fonzie
Nights Camped:2012(36) 2013 (17) 2014 (18) 2015 (18) 2016 (36) 2017 (32) 2018 (42)
fonzie is offline
Old 04-08-2019, 12:55 PM   #8
cavie's Avatar
It is very obvious that what is shown is a 30 amp 120 volt service
cavie is offline
Old 04-08-2019, 01:08 PM   #9
Looks to me that someone used a 50a power distribution box for a 30a shore power service and removed the 50a double breaker and installed a 30a double.
Why else would you jumper the two 30a breakers together (with the jumper below the 30a breakers) if you weren't trying to accomplish what a 50a distribution box does with two hot legs coming into it.
Just as cavie said in post #4.
Days Camped: '15=22 '16=46 '17=30 '18=51
5picker is offline
Old 04-08-2019, 01:08 PM   #10
wmtire's Avatar
I agree with Cavie, you can see at the bottom of the double pole 30 amp breaker, a jumper wire....which indicates a single feed is coming from a 30 amp 120 volt shore power.
2011 Flagstaff 831 RLBSS
As I've told my kids a hundred zillion times, "Don't exaggerate."
wmtire is online now
Closed Thread
breaker
