Old 10-22-2012, 09:27 PM   #31
wmtire's Avatar
Originally Posted by F and E Damp View Post
I'm planning to put a 30A outlet on the outside wall of the garage this fall. We have a C/B on one leg of out panel that supplies a dedicated outlet in the "Computer room", as designated by the builder. We use it as the guest bedroom.
I plan to replace that c/b with the same make and model 30A breaker, disconnect and cap the wiring to the "computer room", then run new wiring to a TT-30R receptacle outside. It will be in a weather-proof box with a weather-resistant "in-use" cover. I'll be getting a neighbor who's a professional electrician to look over my installation before I activate it.
I am assuming the reason you are disconnecting (and replacing) the circuit breaker to the computer room, is because the breaker box is completely full...and you don't have room to add another circuit breaker. (or you are using up all your service amps)
If you still had room/available service to add another breaker, you could just add the 30 amp and run the correct size wire from it to your TT-30R.....without disconnecting your computer room.
Have you looked over the pdf file on making sure you wire the TT-30R correct?
http://www.forestriverforums.com/for...let-27223.html
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
Old 10-22-2012, 09:31 PM   #32
caper's Avatar
AWG states that a 30 amp service needs a min. of 10 guage wire. You have wired a 30 amp service with undersized wire. If by chance you do have a fire that is caused by the wiring your house insurance might not cover the loss. Also if the wiring is ever inspected by the hydro inspector it will not pass. Just because you have been lucky for the last 3 years does not mean your luck will hold. All I can say is good luck to Wildwood 1.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
Old 10-24-2012, 11:11 AM   #33
Anacortesians
You're correct, wmtire. The breaker box is full. That socket in the guest bedroom is in an awkward place and we don't use it anyway. I'll be using 10-gauge wire, even though the run from the breaker is only about 8 feet.
Yes, I've got that leaflet on how to do the hook-up, but I'll still have it inspected by my licensed electrician, RV-owner neighbor. I may even have him do the hook-up inside the breaker box.
Frank and Eileen
No longer RVers or FR owners
Old 10-24-2012, 07:49 PM   #34
wmtire's Avatar
breaker
