Old 10-13-2012, 06:35 AM   #1
30 Amp Breaker in Garage - for TT
I'm wanting to run the 110v "things" that my TT has by using an outlet in my garage and an extension cord. I've searched for info and come up with this : The 30-amp 120-volt 2 pole 3 wir
what I'm getting from the above reference is that the 20 amp breaker in the main distribution box can be replaced with a 30 amp breaker &
then the "normal" 110v outlet would then be replaced with an "RV 30 amp" one &
then for the 100' run I would need a #8 gauge extension cord
is this thinking correct ? (and if so, would anyone here like to come over and do those mods for me ?). thank you.....Bill
p.s.: almost forgot - there are 4 normal outlets on the 20 amp breaker that I'm thinking about changing to a 30 amp - am I correct in thinking that nothing about them would change, other than "capability" ?
Whisky is offline   Reply With Quote
Old 10-13-2012, 06:54 AM   #2
Herk7769's Avatar
Other than you won't be able to use them and they would need to be bypassed.
They are only rated for 15 amps (most likely as the 20 amp duplexes look like the photo)
ALL the wire in the circuit would need to be replaced with 30 amp rated romex house wire as well.
WAY better to leave the 20 amp breaker in the panel and wire the 30 amp rated (but now 20 amp limited) RV outlet with the existing wire.
HAM CALLSIGN - KC3FFW
Old 10-13-2012, 07:05 AM   #3
Originally Posted by herk7769 View Post
..WAY better to leave the 20 amp breaker in the panel and wire the 30 amp rated (but now 20 amp limited) RV outlet with the existing wire.
(I think I understand all I thought I heard you say.....)
so, you're saying NOT to have the 20 amp breaker in the panel replaced - but it would be "OK" to replace the outlet on the wall with a 30 amp one, even tho it would be limited to 20 amps ?
if that's correct, wouldn't a simple adapter be the simple solution ? thanks.....Bill
Old 10-13-2012, 08:02 AM   #4
carl.net
If you have room in your panel then please put in a new 30 amp breaker and run the correct size (or slightly larger) wire from the new breaker to the correct sized outlet. It is much simpler then trying to monkey with a circuit you already have. You will also have a significantly smaller chance of creating a fire hazard with the new circuit then you will trying to retrofit the old one.
There is a very simple rule when working with electricity.
Larger diameter wire = less resistance
Less resistance = less heat
Less heat = less chance of fire
Or to put it another way don't overload your wire or you will pay for it later.
- 06 Salem LE 28BHS (axles flipped), Boliy Pro3600ES Generator
Dodge Dakota 4.7l HO (260hp/310torq), 131 in wheel base
3.92 gears with towing pkg, Reese dual cam sway control
Tekonsha P3 break controller
- 36 ft Monterey cabin cruiser, Stainless blender
Two 4.7 GXi I/O (2 x 320hp = 640hp)
carl.net is offline   Reply With Quote
Old 10-13-2012, 08:55 AM   #5
thanks all - no matter what I have done (IF I have anything done) it'll be done by a "real" electrician.....Bill
Old 10-13-2012, 08:58 AM   #6
TURBS's Avatar
As we've found "real" electricians have messed up thousands of dollars of electronics not knowing an rv is 110v.
Turbs
Old 10-13-2012, 09:39 AM   #7
question : roughly, what amp draw would a Dometic fridge have (26' Wildwood BH).....Bill
Old 10-13-2012, 10:00 AM   #8
TURBS's Avatar
normal appliance amp draws
Old 10-13-2012, 10:01 AM   #9
wmtire's Avatar
Edit: Turbs got it
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
Old 10-13-2012, 10:40 AM   #10
Herk7769's Avatar
20 amps is plenty for most users. Just watch what you plug in to your other outlets.
breaker
