Old 03-31-2015, 08:17 PM   #1
30 amp breaker trips when air conditioner and refrigerator cycle at same time
I have a 2014 Forest River DS3010 (Class C). The fridge is a stainless steel double door model with typical fridge/ freezer combo. As an electrician, I realize that both draw high amps when each compressor is on.
My question is: Other than living with the freezer using gas only or not running ac, is there anything I can do and am I missing something?
jth8696 is offline   Reply With Quote
Old 03-31-2015, 08:21 PM   #2
TURBS's Avatar
You have a gas/ electric fridge not a residential?
If so your gas/ electric fridge doesn't have a compressor.
Even so the fridge only draws 5-8 amps max.
You a/c may draw 20 amps or so to start but runs in the neighborhood of 16
Is this a 50 amp rig or 30?
normal appliance amp draws
TURBS
08 duramax tuned n modded, 32bhok Sabre
Old 03-31-2015, 08:27 PM   #3
Phat Phrog Stunt Crew
elind's Avatar
How do you run your hot water heater? Gas or electric? The electric draws 12 + amps and the AC also draws 12+ amps. If you run the hot water heater on gas it will leave you with plenty of power for the AC and fridge.
2014 Wildcat 327ck
elind is offline   Reply With Quote
Old 03-31-2015, 08:27 PM   #4
Since I don't know thank you for prompt response. But the electric side still has a compressor does it not. My unit can run electric (shore power or generator) just like a residential. Or switch over to gas if I choose. So going to the link you provided with 14 to 16 amp draw for ac and 8 amp draw for fridge I should not be tripping the breaker. Any suggestions...
Old 03-31-2015, 08:29 PM   #5
TURBS's Avatar
No the electric side is not a compressor.
It's actually a heating element.
So true you should not be popping a breaker.
TURBS
Old 03-31-2015, 08:31 PM   #6
"elind", Thank you, that make sense since I was trying to run everything on electric. I honestly don't know about the water heater. One of those questions that I missed during the buyout class on unit. I will have to research the water heater.
Old 03-31-2015, 08:33 PM   #7
As a thought for all who look at this thread. Would it not make sense to have a unit that can handle all power requirements electrically since it does have a generator and appears to be totally self sufficient. This might lead back to a quality issue.
Old 03-31-2015, 08:33 PM   #8
TURBS's Avatar
Keep in mind as long as your plugged in or using the gennie your converter is always drawing amps as well
1-8 amps depending on the 12v load in your camper and battery status.
TURBS
Old 03-31-2015, 08:36 PM   #9
TURBS's Avatar
if your camper is 30 amp service then no you can't run everything and be fine.
Now if you have 50 amp service you'd be better off.
TURBS
Old 03-31-2015, 08:40 PM   #10
As Turbs said, if you have a refrigerator that will run on propane or elec, there is no compressor. You might also have a weak 30A breaker. FR does not furnish the best quality breakers. Just unplug from shore power, remove the breaker and take it to Lowes/HD and get a brand name replacement.
We've only tripped the breaker one time when TOWTA had the mw going, toaster oven, coffee pot perking and the ac kicked on and shut everything down. Shut the mw off and everything was good. I had removed all the breakers previously and bought brand name replacements @ Lowes when the trailer was new. The original breakers went in the blue box with wheels.
air conditioner, breaker, fridge, refrigerator
