Old 06-08-2016, 12:29 PM   #11
TURBS's Avatar
30 Amp extension cable failure
In a cg with low voltage could cause your problem with that long of a run possibly up to 2 or 3 volts with a 20 amp draw.
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
2016 nights camped "10"
Old 06-09-2016, 08:44 AM   #12
Do you have a surge protector? On my new trailer, I cut my original power cord that was stuffed into a "rat" hole and installed the hard wired Progressive Industries 30 amp surge protector with wall indicator and installed the Marinco power disconnects.
Protects my trailer and I can inspect the ends. I also bought a Marinco power cord with molded ends that I always start off with. I took my original 30 ft cut off power cord, installed a 30 amp female plug and have a 28 ft extension cord to use when I need a little longer.
johng4706 is offline   Reply With Quote
Old 06-09-2016, 10:07 PM   #13
billkaz
No surge protector
From previous comments I'll be watching the connectors. Until then, if it ain't broke, don't worry.
billkaz is offline   Reply With Quote
Old 06-10-2016, 07:19 AM   #14
waiter21's Avatar
The cause could also have been a bad receptacle that you were plugged into.
If the connections are loose or worn in the receptacle, it won't make a good connection with your plug. Heat can build up, and damage your plug.
When I plug into a 30 amp pedestal, if the receptacle seems loose, I'll use my 50 amp adapter and plug into the 50 amps (if there is one). Generally, the 50 amp receptacles get less use and are in better condition than the 30 amp receptacle.
2001 Coachmen Mirada (Ford F53 6.8L V10) - Toad 2003 Saturn Vue
It won't do MACH 2, but I can get a sandwich and take a pee.
waiter21 is offline   Reply With Quote
Old 06-10-2016, 05:40 PM   #15
billkaz
Thanks for that suggestion
