Old 06-07-2016, 11:11 PM   #1
billkaz
30 Amp extension cable failure
After 3 trips in 2 months had a failure of a new 30A extension cable while camping. It worked for 2 days running the ac & then mysteriously quit. Had an electrician call ($$) to diagnose the outage before the problem was identified.
Has anyone else experienced this problem with a cable? Golly, how much can go wrong with something so simple?
billkaz is offline   Reply With Quote
Old 06-08-2016, 06:24 AM   #2
TURBS's Avatar
Take the cord back to where you bought it and get a new one.
Btw why did you buy a new cord to begin with?
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
2016 nights camped "10"
Old 06-08-2016, 06:28 AM   #3
AquaMan's Avatar
Loose connections cause heat, which can cause the connections in a plug to come undone. Is this an extension added to your regular power cord?
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 7
Old 06-08-2016, 06:31 AM   #4
Aqua is on it,Main power cord was prob "Burnt" causing Heat build up! Youroo!!
youroo is online now   Reply With Quote
Old 06-08-2016, 06:53 AM   #5
Exactly
Most likely burnt where the wire is soldered to the brass prong or lug inside the molded plugs. Get some replacement Camco power grip ends and fix the cord?
They solder the connection in those molded plugs. When you have a loose connection at the pedestal and the cord end heats up, the first to thing to fail is one of those soldered joints.
I doubt you burnt a wire in the middle of the cord somewhere.
Mr Havercamp is offline   Reply With Quote
Old 06-08-2016, 07:03 AM   #6
Head Rambler
I hate those molded on ends. About the first thing I do when getting a new RV or cord is to replace the molded on ends with aftermarket ends.
I also carry a 50A male-30A female dogbone adapter, and if the 30 amp plug looks abused or if when I plug the cord into it, it isn't good and tight, I use the 50A>30A dogbone.
Gotta go campin!
Old 06-08-2016, 07:09 AM   #7
Me too
I have 3 or 4 30 amp cords that started out as 30' and are now all 28' or so.
Old 06-08-2016, 11:02 AM   #8
billkaz
30 A cord
That computes, soldered connection failing. Have made an exchange for a new cord, will watch this one closely.
Thanks for all the replies
Old 06-08-2016, 11:19 AM   #9
TURBS's Avatar
How long is your normal cord?
How long is ext cord?
2015 Columbus 320RS
2008 2500HD Duramax
Old 06-08-2016, 12:28 PM   #10
billkaz
The trailer cord is about 20' & the extension is 30'
