Old 02-03-2016, 04:52 PM   #1
Admiral_Roo2's Avatar
30 amp extension cord for generator
Taking a 3 week trip in June from Alabama to Yellowstone and back, bought a generator to mount behind cab in truck bed in case we have to freestyle in a parking lot etc. Wondering if I buy a regular 25 foot RV 30 amp power cord like the one my unit came with and plug them together if it will work ok to run the generator. I really only need about 10 feet of it but CW just has the standard 25 footer. I've had problems with my air compressor not working unless it was plugged into wall since the regular ext. cords I have don't have the specs of the cord coming out of the compressor, so I'm concerned with a similar issue causing the AC or anything else I run in the trailer not working because of power loss with the daisy chained cables. Any experience / ideas on this? The guy at CW says no problem but I'm still not convinced and don't want to buy it if it's not going to work. Thanks.
TV - Whatever I can rent!
2014 Rockwood Roo 25RS
Nights camped 2014 - 27, 2015 - 28, 2016 - 31
Nights camped so far 2017 - 16
Admiral_Roo2 is offline   Reply With Quote
Old 02-03-2016, 05:04 PM   #2
Head Rambler
As far as the length of the cables you should be fine. I'm assuming that it's #10 awg wire.
My question would be what size generator do you have? Hopefully it's not a single 2000 watt model. You'll need more than that to run the A/C.
Gotta go campin!
Old 02-03-2016, 05:10 PM   #3
Not sure on the gauge but they would both be the standard RV size for a 30 amp, and I'm only going about 35 feet-ish. Figured with them matching it would be fine but I tend to err on the side of paranoid. I'm good on the generator, 3500 / 4000 watt. Thanks for input. Happy travels!
Old 02-03-2016, 05:11 PM   #4
fonzie's Avatar
I have run my travel trailer electrical off my generator using two 25 feet RV 30 amps extension cords with no issues....but if you want a 10 foot extension cord you can get it at amazon....
Robot Check
Fonzie
Old 02-03-2016, 05:14 PM   #5
Yes, need Info on Type and output of Gen! Most Quiet Gens that are Large enough to Run 1AC have a 30A Outlet built in! Youroo!!
Old 02-03-2016, 05:35 PM   #6
Thanks for feedback
Robot Check
I saw the 10 footer on Amazon but I can get the 25 for $32 with a coupon so it made sense to just get the longer one. Thanks.
Old 02-03-2016, 10:47 PM   #7
PokerDealer's Avatar
Make sure to check the gage of the wire in the extension cord you are going to use. 12ga. would be a minimum. I got a 10 ga, on line, you can also check Haber Frieght or WallMart
2015 Wildwood 181 BHXL. 2005 1500 Ram Hemi 4x4 W/package
PokerDealer is offline   Reply With Quote
Old 02-03-2016, 11:03 PM   #8
Oklahoma Proud
MillerTime's Avatar
Op, i would make sure you wire the plug to only have one leg hot. Some 4 prong genny plugs have 2 hot legs.
12 guage is only rated for 20 amps, 120v a/c
10 guage is rated for 30 amps, 120v a/c
Old 02-04-2016, 02:25 PM   #9
Also, make sure you buy an extension cord, not a duplicate of the original power cord as the plug ends won't match up!
Backpacker
glfillion is offline   Reply With Quote
Old 02-04-2016, 02:54 PM   #10
You might get some 10-3 heavy rubber cord and plug/receptacle ends and make yourself. Home Depot
Harkerr is offline   Reply With Quote
generator
