Old 09-15-2012, 01:02 PM   #1
30 amp fuses blowing battery power only
The 30 amp fuses are blowing, The shore power is not hooked up, Battery polarity is correct, When shore power is attached here is no voltage between the blue wire and the ground in the converter. Everything tells me the converter is bad. Sombody please correct me .
general tinkerer but not an expert by any means
Bill
Bioteach is offline   Reply With Quote
Old 09-15-2012, 01:38 PM   #2
Bill
If you are getting power into the converter and no output from the converter your converter is bad.
Iggy is offline   Reply With Quote
Old 09-15-2012, 02:37 PM   #3
Triguy's Avatar
I'd have to agree. Although you could look to try and repair, they're not typically expensive to replace.
What model converter do you have and what year and model trailer?
Welcome by the way.
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 09-15-2012, 03:54 PM   #4
Dave_Monica's Avatar
I'd agree about the converter, but would that explain why the OP is blowing the 30A fuse off the battery when shorepower isn't connected. Is the dead converter creating a short to ground on the 12V side?
Dave
Old 09-15-2012, 04:01 PM   #5
Welcome by the way.
Thanks for the welcome
We are newbies and started with a 2009 Wilcat 25rl The converter and panel are a Parallex 7100 55 amp
Bill
Old 09-17-2012, 10:49 AM   #6
Triguy's Avatar
Dave
I'm not sure "why" it would. Rumor has it there may have been a problem in 2008 with this Parallax power center. I hate to link to another site , but here's a description. The solution was to replace the circuit board or replace the whole unit.
We don't see many Parallax here so I've added some manuals for Bill. Maybe this will help.
File Type: pdf Parallax 7100 Series Installation Guidelines.pdf (485.8 KB, 74 views)
Scott
2012 Shamrock 233S
Old 09-17-2012, 10:58 AM   #7
Triguy's Avatar
This one is more clear on how to troubleshoot...
Scott
2012 Shamrock 233S
Old 09-17-2012, 11:55 AM   #8
Great troubleshooting chart
battery
