Old 03-26-2013, 03:29 PM   #11
On the (Bourbon Trail) in KY. we encountered a C/G in Bardstown,KY. (50) amp only! They had adapters for rent & sale,we had our own adapters we travel with. Youroo!!
youroo is online now   Reply With Quote
Old 03-26-2013, 03:31 PM   #12
Originally Posted by RVChick View Post
That is how we do it! Now we can run a space heater in the bedroom, coach, and garage area and I only use my propane for cooking.
We run an EdenPure electric heater on a separate (added)15amp circuit and very seldom run the furnace. I also wired the furnace blower to run independent of the furnace burner itself. Works pretty good at circulating the air. Have never had a problem.
Old 03-26-2013, 03:33 PM   #13
Thousand Trails Mockville, NC has a lot of 50 amp only sites and you have to use an adapter for 30 amp.
Old 03-26-2013, 03:46 PM   #14
Phat Phrog Physician
SabreDoc's Avatar
Question
Hi OldCoot,
Wouldn't putting the Fan switch to On/High or On/Low and turning the AC/Heat switch to Off on the AC/Furnace control accomplish the same thing without the need for a re-wire?
Doc
Ron, Amber & Jordan
2011 RAM 3500 DRW/CC/LB Longhorn 3.73
2014 Sabre 35QSIK-6 Platinum Edition
SabreDoc is offline   Reply With Quote
Old 03-26-2013, 03:52 PM   #15
Originally Posted by SabreDoc View Post
Hi OldCoot,
Doc
Would circulate the air in the trailer, but not thru the storage area where all the pipes, etc are, thus the re-wire on the furnace. Not that big of a job if you say it fast. lol
Old 03-26-2013, 03:55 PM   #16
Phat Phrog
RVChick's Avatar
Originally Posted by BarryD0706 View Post
I would think that your breaker box has a 30-amp master breaker so it seems unlikely that this would allow you to increase your electrical usage. If it doesn't, a 30-amp coach is still only using wire that is sized for 30 amps, so you're asking for trouble to pull more.
I bet u r right.
Kenny n Karen
TV: 2007 Chevy Silverado 3500 DRW - named Alice
RV: 2012 XLR Thunderbolt 35x12 - named Thor
RVChick is offline   Reply With Quote
Old 03-26-2013, 05:25 PM   #17
exrpfd110's Avatar
Question from an electrical stand point. If the main breaker on the RV IS 30 amp and you are hooked to a 50 amp service, wouldn't you trip the 30amp side if trying to draw too much power?
exrpfd110 is offline   Reply With Quote
Old 03-26-2013, 05:52 PM   #18
Herk7769's Avatar
That is correct.
The main breaker in the camper would trip before the pedestal in that case.
HAM CALLSIGN - KC3FFW
Old 03-26-2013, 05:54 PM   #19
caper's Avatar
If you are drawing over 30 amp the main breaker should trip. If it does not you could be in trouble with the wiring in the trailer. If you do start to trip the main breaker it will start to get weak after a while.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
Old 03-30-2013, 03:56 PM   #20
wneise's Avatar
I know that if I run the AC and the electric element in the water heater, it pops the 30amp main.
wneise is offline   Reply With Quote
