Old 03-26-2013, 02:40 PM   #1
exrpfd110's Avatar
Exclamation 30 amp hookup
Question to the floor, new 291QBS owner here. I was going to a campground and all they had avail. was a 50 amp hookup. Can i use my 30 amp at a 50 amp site.
exrpfd110 is offline   Reply With Quote
Old 03-26-2013, 02:49 PM   #2
wmtire's Avatar
Absolutely, provided you have a 50 amp to 30 amp adapter. Here is an example of what is called a dog-bone adapter.
They also make this type adapter below.
I prefer the dog-bone adapter as it will usually let you close the door on the park pedestal, where the second type sticks out too far to shut the door.
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
Old 03-26-2013, 02:49 PM   #3
Fulltime family RVer
Almost always, the 50amp site has both a 50amp plug-in AND a 30amp plug-in. Many times, they'll even have a pair of 15/20 amp plug-ins.
In the unlikely event that they don't, RV stores carry a 30amp (female) to 50amp (male) adapter that makes it so that you can plug your 30amp cord into the 50amp outlet.
It might be worthwhile calling the campground to see if they have both of if you need to pickup the adapter ahead of time.
Old 03-26-2013, 02:50 PM   #4
You're right, but my experience is that typically the adapter isn't needed. I'm sure there are cases where it happens, but I think the "norm" is that both are offered on a 50amp site.
Old 03-26-2013, 02:52 PM   #5
exrpfd110's Avatar
Thanx all, very helpful info. I guess i'll be using this site for a lot of questions.
Old 03-26-2013, 02:53 PM   #6
TURBS's Avatar
Were here 24/7
Old 03-26-2013, 02:59 PM   #7
wmtire's Avatar
Yes you are correct ependydad, every now and again you will get a pedestal where the 30 amp outlet is bad or loose (especially since the 30 amp outlet is used much more than the 50). I just came back from a park where the 30 amp outlet was wore out basically, and had a bad connection. I had to pull out my adapter and use the 50 amp outlet. It's one of those things to have just in case.
Old 03-26-2013, 03:03 PM   #8
exrpfd110's Avatar
Going to the Store!
On my way to the store to get the adapter.
Think I'll go for the dog bone style rather than the straight out one.
thanx again all......
Old 03-26-2013, 03:04 PM   #9
Phat Phrog
RVChick's Avatar
That is how we do it! Now we can run a space heater in the bedroom, coach, and garage area and I only use my propane for cooking.
Kenny n Karen
TV: 2007 Chevy Silverado 3500 DRW - named Alice
RV: 2012 XLR Thunderbolt 35x12 - named Thor
RVChick is online now   Reply With Quote
Old 03-26-2013, 03:20 PM   #10
I would think that your breaker box has a 30-amp master breaker so it seems unlikely that this would allow you to increase your electrical usage. If it doesn't, a 30-amp coach is still only using wire that is sized for 30 amps, so you're asking for trouble to pull more.
