After having my PI EMS cut power due to low voltages many times in the past 3 years I decided last year that I wasn't going to put up with low voltage problems anymore, so this Spring I purchased a
Hughes Autoformer to boost the voltage. If it ever gets hot enough up here this summer I may get to test it under those (crowded CG) conditions. I've only used it once and it did boost voltage from about 116V at the panel to about 122V into the TT.
I second all the recommendations to keep adapters on hand. Our TT has a 30A power center and I use the 30A plug if its in good condition and doesn't present any power issues. I'll only use the adapter to plug into the 50A receptacle if the 30A side is a problem, or even suspect looking.
