03-03-2015, 01:22 PM
30 amp or 50 amp surge protector?
I am about to get delivery on a 2015 FR3 30DS. (Yeh!) Is the electrical service 30 amps?
I read a number of posts recommending the use of a surge protector (Progressive). Some posts say 30 amp, others 50 amp. The posts I read seemed to imply the RV service was 30 amp.
If your RV amp service is 30 amp, should't your surge protector also be 30 amps?
03-03-2015, 01:27 PM
You can use a 50 amp progressive ems on a 30 amp trailer.
That way if upgrade units down the road that has 50 amp service you can pull it out of your current unit and put it in the new one.
03-03-2015, 01:33 PM
Average Joe
According to the FR website it's 30 amp.
Joe and Karen
2014 Sunseeker 2450sf
Southern Maryland and Beyond!
03-03-2015, 02:05 PM
Your Welcome Turbs! and Yes I answer some of my own Questions! With Help from PI! Youroo!!
03-04-2015, 01:27 PM
We downsized from an older 5th wheel with 50 amp service to an FR with 30 amp connection and distribution panel. We use our 50A PI and it works just fine. The only slight inconvenience is that you also need one or two dog bones to make the connections. You only need one dog bone if connecting your 30A trailer to a 50A pedestal, as the PI is a direct plugin to the 50A pedestal. Then you need a 50A male to 30A female dogbone to support use of the 30A trailer cable. When operating with a 50A pedestal to a 30A trailer, only one leg of the 50A pedestal is working. [The second leg is vestigial like a human appendix.] The one leg is providing 50A through the PI to the trailer, and your trailer AC distribution panel is circuit breaker controlled to 30A to protect from overload.
2013 Flagstaff 8528IKWS, 2006 F-350 6.0L
03-04-2015, 05:53 PM
Very important to use a surge protector! We had a 148 volt spike at a campground last Spring, which would have fried our AC and frig if it wasn't for the 50 Amp protector we just installed.
03-04-2015, 06:12 PM
Summer2Go
I checked the info on the hybrid I ordered, and I see no reference to 30 or 50 amp. Would a small Roo require a 30 amp serge protector? Do you leave it hooked up outside be the pole? Would it get stolen?
03-04-2015, 06:22 PM
Yes... If it's a Roo, it's going to be a 30-amp. I believe you typically don't get into 50-amp until the unit is big enough to have 2 A/C units.
There are two types... One that connects to the pedestal then to your camper cord, and one that you hard wire inside your camper. I have the one (Progressive Industries) that connects to the pedestal. I use a bike lock for mine, wrap it around the pedestal and lock it. Never had an issue. I like being able to peak out the window and see how many amps I'm drawing.
2015 Coachmen Apex 288BHS
2014 Toyota Tundra 5.7L CrewMax
2014 Toyota Tundra CrewMax 5.7L
Hard wire inside! Youroo!!
03-04-2015, 06:25 PM
If I had it to do again, I would have bought a 50 amp the first time. Had to upgrade when we did, and yeah, you'll probably upgrade. As Turbs says, 50s work for 30A; just don't go without!
2014 8528 IKWS
Ford F-250 Diesel
Cricket the Cairn and Sally the Terrier Muppet Mix
03-04-2015, 11:12 PM
Yes, the portable surge protectors are subject to theft. However, the two manufacturers I am aware of provide devices that allow you to padlock them to the pedestal. The hard wire models, primarily for Class-A campers and most 5th wheels, installed in the RV basement and are not visible from the outside.
03-07-2015, 06:31 PM
Summer2Go
Do you know the brand name? I looked at a picture on the CW site and I didn't see any loop or way to bike lock it to the pedestal.
03-07-2015, 06:48 PM
I just use two keyed alike locks and a 4 foot hunk of chain.
use one lock between a plug and the main body around the cord and then use the other lock thru the chain links around the power pole.
03-08-2015, 08:07 AM
05-22-2020, 11:49 AM
I just received a new camper, forest river 2506S. It came with a 30 amp service, I know sometimes your only choice is a 50 amp service, I also want to use a surge protector, is the only way to go from 50 to 30 a dog bone, or is there a 50 to 30 amp plug. My concern is going from 50 to a 30 dog bone then having my surge protector hanging down so low.
05-22-2020, 01:48 PM
They make plugs as well but I would caution you on them.
I just got back from a trip where my friend has a 50A EMS and a 30A trailer. He previously had a 50A trailer. He used these
https://www.homedepot.com/p/AC-WORKS...50TT/305439317
The issue is they stick out fairly far.
1. You cannot close the electrical box
2. They stick out and weigh down the plug causing poor contact.
He plugged in and all was fine until he turned on an electric heater. You could hear the arcing on the plug and it shorted out. It could have melted pins but the EMS tripped due to voltage instead. He was lucky the voltage dropped or he would have fried a plug.
I would stick with the dog bone and put the EMS in a tub or under a bucket if you are worried about it.
05-22-2020, 02:43 PM
Thanks, looking at the plugs, I did decide on the dogbone just for that reason, with the length of the plug and the weight. This way everything will be aligned.
