07-23-2018, 01:19 PM
30 Amp Question
We have a travel trailer that runs on 30 amp. When I plug in my 30 amp to the electricity using the regular 30 amp male plug it doesn't work. It only works when I use the 110 adapter and plug into the 110 or regular type electricity socket. Any ideas why?
2004 Flagstaff 228 MAC - Retired
2015 Coachmen Clipper 17BH - Current
07-23-2018, 01:22 PM
Insert witty title here
Is the 30A socket powered up?
2021 Transcend Xplor 247BH
Husky WDH with Sway Control
2021 Chevy Silverado 2500HD LT 6.6L V8 Duramax
Forever in my memory. Forever in my heart.
Laurie J. Wood 3/22/67 - 8/23/19
07-23-2018, 01:24 PM
I assume it is. This has happened at multiple different campgrounds, I thought maybe I am doing something wrong. It works fine when I use the adapter but I'd like to not have to use the adapter all the time.
07-23-2018, 01:29 PM
I am assuming that by saying :Plugging into 110 you are using an adapter to plug the TT into a standard 15/20 A household outlet. If it works with the adapter, then RV power cable is OK. If it doesn't work when you use the 30A RV plug directly into the pedestal, then either the outlet in the pedestal or the breaker in the pedestal is bad or turned off. Try turning the 30A breaker in the pedestal off and on.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
07-23-2018, 01:30 PM
Campgrounds usually have circuit breakers above their outlets. Are you making sure to turn on the circuit breaker at the campground pedestal?
2011 Flagstaff 831 RLBSS
07-23-2018, 01:31 PM
The adapter just goes on the end of the 30A cord, so it shouldn't be anything with the cord/trailer. At a lot of parks, people turn off the breaker to the 30 when they plug in/unplug, not so much the 20A breakers. Next time you're out, check if the breaker's on?
07-23-2018, 01:32 PM
Just as confused as you
Some people turn the pedestal breaker off before plugging in and unplugging their RV. If the previous camper turned the breaker off and left it off then you will have to turn the breaker back on, preferably after you plug in. Turning the pedestal breaker off when you plug in/unplug saves your plug from the arching that happens. In other words it's a good idea along with using a multimeter to test the outlet for proper voltage before you plug in.
Richard & Jill
07-23-2018, 01:33 PM
As a couple others said, make sure the 30 amp breaker is on in the panel on the pedestal. More often then not, they have been flipped off in the campgrounds we have visited. I've even gotten into the habit of flipping them off if they are on when I plug in, then flipping it back on and flipping it off again, when I unplug.
07-23-2018, 01:37 PM
Ok, thanks everyone. I will check the breakers on our next trip. hopefully that is the issue.
07-23-2018, 01:41 PM
Here is an example pic of a campground pedestal (but styles/outlets vary by campground).
In this pic the circuit breaker #2 would control the 30 amp outlet. As good camping practice dictates, you do want to flip this circuit breaker off before connecting... or prior to disconnecting your RV's power cord to keep the arcing from occurring.
07-23-2018, 01:51 PM
I don't see a pic.
07-23-2018, 01:57 PM
We see the photo in both posts.
Try another browser.
Peace!
Dan & Rita D
07-23-2018, 01:58 PM
I don't see a pic.
You don’t see a rectangular picture of a gray power box? I see it in the original and where you quoted the original.
07-23-2018, 02:31 PM
I don't see a pic.
If you are perhaps using internet explorer 11, this link may help.
https://support.microsoft.com/en-us/...ompatibility-v
07-23-2018, 04:16 PM
Certified Curmudgeon
It is a good practice to turn the breaker on the pedestal off before plugging in and before pulling the plug. When I leave a campsite, the breaker is off.
Mike Dropped
07-23-2018, 07:18 PM
If your air works , your on 30 amp
