Old 05-19-2018, 08:58 PM   #1
30 amp surge protector recommendations
I am interested in getting a surge protector. My camper is 30 amp. I also use a 50 amp to 30 amp adapter when there is only 50 amp power supply available.
What type/ brand surge protector is recommended and can also be used with the 50/30 amp adapter when it is in use?
ArkansasGreyWolf is offline   Reply With Quote
Old 05-19-2018, 09:11 PM   #2
Who Dares, Wins
doc73's Avatar
Progressive industries EMS. Had a 30 amp one then traded another member here for his 50 and my 30 when we upgraded to a larger 5er.
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is offline   Reply With Quote
Old 05-19-2018, 09:36 PM   #3
cavie's Avatar
Surge protector and EMS surge protector are two different things. A surge protector is just that. It stops hight voltage spikes. Ems protect from improper wiring and Hight and low voltage.
2002 27rk Wildcat 5er.
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
Old 05-19-2018, 09:39 PM   #4
Who Dares, Wins
doc73's Avatar
Yep but my EMS does both things.. not just a surge can damage things,low voltage can be just as bad or a bad wiring job.
2015 ChevyHD D-Max
Old 05-19-2018, 09:50 PM   #5
x2
Our portable Progressive EMS has detected open ground, reverse polarity and on several occasions shut down the power temporarily when low voltage was detected.
Still we used a surge protector that detects reverse polarity and open ground for our trailer.
Happy Camping!
2015 Dynamax REV 24TB class C
2nd rig 2006 Toyota Tundra &
2010 Cikira 21RB 19' travel trailer
Reverse_snowbird is offline   Reply With Quote
Old 05-19-2018, 10:07 PM   #6
dbledan's Avatar
Buy the PI 50 amp EMS. You can convert it down to 30 and use it. Then if you upgrade later you don't need to buy a second one. Adapters are $15 and all you would be out if you never needed 50A.
dbledan is offline   Reply With Quote
Old 05-19-2018, 11:14 PM   #7
Is this what you are referring to?
Old 05-20-2018, 12:08 AM   #8
I probably need the 30 amp ems in case I only have a 30 amp receptacle available.
Old 05-20-2018, 09:22 AM   #9
Fulltime family RVer
You match the EMS to what your rig is wired for. You CAN use adapters, just like your power cord.
Info and links here:
What Surge Protector is best for my RV? | Learn To RV
Old 05-20-2018, 01:46 PM   #10
jbrosecity's Avatar
I just bought this one
Progressive Industries 313.1168 SSP30X Smart Surge Protector - 120V/30A
https://www.amazon.com/gp/product/B015G2YYN0/
Progressive makes a sound unit with a good price... added a short length of chain and a long shackle padlock to lock it to any pedestal
2019 Forest River Forester 3041DSF
Ford E-450 Chassis
www.Wind-seeker.com
jbrosecity is offline   Reply With Quote
