Old 12-09-2015, 08:00 PM   #31
Flybob's Avatar
If you search the forums, you will see incidents of reverse polarity and other issues not covered by the less expensive unit. Also most surge protection components are single use sacrificial devices. If the inexpensive units blocks a surge after the one year warranty, you buy a new one. The PGI is replaced for the life of the unit. Easily worth the extra expense to me, but it is your RV and your choice.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 12-09-2015, 08:16 PM   #32
I go RV'ing not Camping
jgourlie's Avatar
That is a good point about the surge protection. I hadn't considered it may damage the unit after 1 incident
312QBUD Owners Thread
2015 Wildwood Heritage Glen 312QBUD
2000 Chev 2500 Extended Cab 6 Liter
1400lbs Equal-i-zer Hitch
jgourlie is offline   Reply With Quote
Old 12-10-2015, 05:23 AM   #33
davel1971's Avatar
Originally Posted by jgourlie View Post
I am still not certain the $80 price difference for the progressive makes it worth it over the Camco
the fact that the PI unit is the only one of them all that will prevent 220 volts from frying everything in my 5th wheel is good enough reason alone. Lifetime warranty means this unit will outlast any RV
David & Lynn
Old 12-10-2015, 08:27 AM   #34
OK lots of votes for the Progressive, but not lot of good data as to why.
The lower priced units are surge protectors only. .
And that is why Progressive wins hands down. They protect your electric system for just about everything that you can run into at a cg. There are many problems you can run into at cg's you need protection from, plus they give a life time warrantee which is important. And it is made in America!
Jim
07 Dodge 1500 crew cab with 20" wheels, 08 Forest River Rockwood Signature Ultra-lite 8280SS
"The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore, all progress depends on the unreasonable man."
George Bernard Shaw
oldtool2 is offline   Reply With Quote
Old 12-10-2015, 03:13 PM   #35
360true's Avatar
I was hit last week with a major high voltage series of spikes and my Progressive 50 amp portable protected my air and residential fridge and electronics. The last spoke "blew" the unit so it wouldn't reset. On Sunday, I called and received a call right back. It needed to be sent back for guaranteed repair/replacement. 1) Made in the US 2) Guaranteed for life and 3)They call you back. Doesn't get any better than that!
360true is offline   Reply With Quote
