Old 03-29-2013, 05:36 PM   #1
30 amp to 50 amp adapter.
I am going to get a 30 to 50 amp adapter for times when the 30 amp connection might be bad or unavailable. I have this cord (yellow) from the camper to the black cord which just let's me plug in to the house farther away.
Now here is the adapter from black cord to house
My question (this may sound dumb but I'm new to all this so better safe than sorry) is that this black cord would be fine being used with the adapter right? It would still be like 30 amp going through right?
Grey9712 is offline   Reply With Quote
Old 03-29-2013, 06:04 PM   #2
Can't really tell anything from your cord pictures.
It sounds like you have a 30-amp RV. You will be fine with using a 30 to 50 adapter to use as you described. Make sure you buy it at an RV supply place (not Home Depot or Lowes, etc.).
The only potential problem is that the 50-amp breaker in the pedestal won't trip at 35 amps, so you'll be relying on the master breaker in your RV (which should be 30 amps) to protect you for over-current. That should be ok.
Old 03-30-2013, 07:41 PM   #3
My camper is 30 amp.So would this work
Power Grip Adapter - 50A Male to 30A Female - Camco RV 55175 - Electrical Adapters - Camping World
Old 03-30-2013, 07:50 PM   #4
CLASS "A" Senior Member
cfsoistman's Avatar
Originally Posted by Grey9712 View Post
You've got it. That will enable you to plug into a 50 amp receptacle at a campground and plug your 30 amp cord into it.
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
cfsoistman is online now   Reply With Quote
Old 03-30-2013, 07:51 PM   #5
Yep, that will do it.
Old 03-30-2013, 09:37 PM   #6
Engineer of Crazy Train
ChooChooMan74's Avatar
That is what I got. I am planning on using an RV 50 amp pedestal from Home Depot (they don't carry the 30 amp one locally) and use the adapter when home. Then, when I upgrade, I will be ready.
TV - 2015 Ram Truck EcoDiesel
TT - 2015 Rockwood Roo 183
Locomotive Engineer
Nights Camping --- 2015 - 19 Camped | Winterized -- 2014 -18
Come read my Camping Blogs
ChooChooMan74 is offline   Reply With Quote
Old 03-31-2013, 07:43 AM   #7
sail2liv's Avatar
If you don t have surge protector, I would at least check the voltage with a meter that is coming out of the adapter....to make sure it is 110-120.....and has only one hot pin......surge protector should be one of first items on wish list....
2011 Silverado 2500HD 6.0 Gas 3.73
2013 Flagstaff 8524 RLWS
1978 Cape Dory Ketch
sail2liv is offline   Reply With Quote
