Old 08-28-2013, 08:50 AM   #1
30 Amp Trip
How much 110+ power can you use in your unit before a Breaker trips? This would be at the Same time. Youroo!!
Old 08-28-2013, 08:58 AM   #2
Dave_Monica's Avatar
I have a digital readout of the amps load from my hard-wired surge protector and have seen 32-33A displayed. I then shut something off as I know a trip will follow if left a while.
Dave
Old 08-28-2013, 09:35 AM   #3
Herk7769's Avatar
HowStuffWorks "Basic Circuit Breaker Design"
There are two types of breakers. MOST inexpensive ones use a bi-metallic strip that needs to get hot enough to bend away from the contact to trip the switch to the "tripped" position.
Since the "quickness" of the trip depends on how much heat is being produced, a small overload can take several minutes to heat the strip enough to release the switch. The higher the overload current the quicker it will trip.
Some breakers use an electromagnet to pull the trip lever. Once the overload current reaches a point where the magnet is strong enough, the circuit will open.
Even with the electromagnet style, there are tolerances (say 30 amps + 1 amp). The circuit may open early or late depending on where the actual current flow needed to trip it falls.
HAM CALLSIGN - KC3FFW
Old 08-28-2013, 10:04 AM   #4
TURBS's Avatar
Why u ask ?
Old 08-28-2013, 10:08 AM   #5
Maybe you're asking "power", normally measured in watts? That would be about 120x30= 3600 watts.
Old 08-28-2013, 10:11 AM   #6
Herk7769's Avatar
Depending on what is going on in the camper at the time, I have seen my AC amperage meter spike above 30 amps (31 or 32) several times over the last few months without tripping the post or camper main breaker. Since the spike never lasts more than a few seconds (typically a hair curler in use when the AC kicked on) the breakers hold.
Old 08-28-2013, 03:10 PM   #7
Originally Posted by f1100turbo View Post
Why u ask ?
Just seems to be several members say they can use (ALL)-MW-A/C-W/H-Coffee Maker-Hair Dryer- and not trip a Breaker! I don't buy it. Youroo!!
Old 08-28-2013, 03:17 PM   #8
I think some of it could be A lot of those items cycle. A/c Compressor not always running and when it is its relatively low amperage (10-15) its the kick in that's hard, and most of the time breakers will handle a fairly large start load. Some coffee pots hot plate cycle with temp, microwaves cycle.
I have run A/C, coffee pot and hair dryer at same time.
Acableguy06 is offline   Reply With Quote
Old 08-28-2013, 03:24 PM   #9
Witch Doctor's Avatar
Herk, I just sit and wounder how you have all this information. What you posted is exactly true. A breaker will hold up to 10% over the rating for a short period of time such as a surge, but will trip if if it is longer then seconds. That is why you size a breaker for start up amps like your A/C when it comes on. With saying that it will only hold for seconds until the motor gets out of the start wind and into the run amps. You just constantly amaze me with your post.......
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Witch Doctor is online now   Reply With Quote
Old 08-28-2013, 03:34 PM   #10
Youroo, It will depend what you have on and using at the time there is number of post on what the amp draw is on different 110V Appliances. Then you have to think about the amp draw that you plug into the electrical sockets and is running at the time. Would I have my microwave running with my A/C and my wife drying her hair? The answer is no it would trip a 30 amp breaker every time. I would hope the trailer tripped before the pedestal.........
