Old 03-09-2015, 10:51 AM   #1
30 or 50 amp
I ordered a new wolf pack 315 and didn't see where it was a 30 or 50 amp. I called and its 30amp. My question is do you think 30 amp is ok. We will run ac, 2 TVs, dish sat, and maybe microwave at most at same time if it can. Occasional hair dryer, fan at night, coffee maker in morning. This is second trailer for us and I haven't had trouble b4 but didn't have dish sat. Thanks and please educate me!
Arkguy29 is offline   Reply With Quote
Old 03-09-2015, 10:55 AM   #2
B and B's Avatar
Hello, 30 amps will run all items. You might have to avoid the hotwater heater when running in hot weather if you want the Microwave, other than that it will work just fine, TV and Sat do not draw that much. I run my trailer with 30 amps and 15 K BTU AC unit as well.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 03-09-2015, 10:57 AM   #3
wmtire's Avatar
Mark Polk has a fairly good article and approximation chart on how many amps a lot of common appliances use here. It may help and you can kinda add up what it all takes:
RV Converters and Amp Draw - RV Information (RV Maintenance)
1500 watt Hair dryers and space heaters are also pretty big energy users (12.5 amps per and better). You may need to watch what else is on (and needs to be turned off) at the same time when using either/or
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
Old 03-09-2015, 11:26 AM   #4
I've always used gas on hot water heater bc of recovery rate and fear of breaker tripping.
Old 03-09-2015, 01:24 PM   #5
I'd be wary of running two ACs on 30 amps.
Iwritecode is offline   Reply With Quote
Old 03-09-2015, 01:27 PM   #6
wmtire's Avatar
I may have missed something here? I saw where the OP discussed two televisions, but not two A/C's.
I would think any RV's with 2 air conditioners would be a 50 amp variety from the factory?
Old 03-09-2015, 01:32 PM   #7
TURBS's Avatar
True,
30 amp one a/c
50 amp two a/c's
Old 03-09-2015, 01:34 PM   #8
TURBS's Avatar
Originally Posted by TURBS View Post
True,
30 amp one a/c
50 amp two a/c's
I have 30 amp and run:
2 tv's
A/c
Satellite and receiver
2 fridge ' s
And water heater.
I have 2 microwaves but can only run one @ a time.
Old 03-09-2015, 01:44 PM   #9
trbomax's Avatar
Are you sure its only 30a? We got our 315 in nov and its 50a.Does your power cord pull out or plug into the side of the trailer? # prong plg or 4?
trbomax is offline   Reply With Quote
Old 03-09-2015, 01:53 PM   #10
I ordered it. Been 5 days since down payment. I didn't see where it had a 30 amp or 50 amp on order sheet. I selected a 15 ac unit. I called and asked and they said it was 30. Should I change it to 50 if possible? How do you like your unit? I am buying a few things each week for it and wondered which surge protector to get. I may wait until it arrives.
50 amp
